[Mapserver-users] override headers in CGI request in 4.0
Michael Schulz
mschulz at webgis.de
Wed Jul 16 02:33:42 EDT 2003
while going through the last posts i found this one below, and wanted to
investigate further since i experienced the same problem, that i can't
change a layer's header/footer template file via cgi/url parameter, for
the main template it works. I don't have the latest mapserver, so
perhaps someone who does could check if this is really not working.
MapServer version 4.0-beta1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=JPEG INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
Cheers, Michael
Jerfaas de Jong schrieb:
> Hi,
> In 3.6 I overrided my default headers in a query like this:
> ..&map_querylayer_header=newheader.html&...
> In 4.0 I can only override my template file in a query by either
> posting, but not the header file:
> ..&map_querylayer_template=newtemplate.html&...
> ..&map_web_template=newtemplate.html&...
> What am I doing wrong in 4.0 (it worked in 3.6) ?
> Thanks in advance,
> Jerfaas de Jong
> ______________________________________________________
> This message has been checked for all known viruses
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
