[Mapserver-users] Class Expression help
Nick Petersen-Bergeron bergeron at zedxinc.com
Thu Jul 17 07:50:30 PDT 2003
I'm trying to do a class based layer structure for a map program I'm
writing.  I've looked through all of the syntax examples for expressions
that I can find, but can't seem to figure out what's wrong.
I have around 20 classes in the layer.  Essentially the only thing that
will differ between classes is the color.
I've included an example of one of the classes.
CLASS
                 EXPRESSION "(('[TEMP]' eq 'normal') AND ('[PRECIP]' eq
'normal') AND ([LEVEL] eq 0) AND ([DAY] eq 30))"
                 COLOR 50 50 50
                 SIZE 5
                 NAME "normal_city"
                 SYMBOL "circle"
                 LABEL
                         COLOR 50 50 50
                         FONT arial
                         SIZE 12
                         POSITION ur
                         ANTIALIAS TRUE
                         TYPE TRUETYPE
                 END
         END
Can anyone see a problem with this?
When I comment out a single expression, the shapefile I'm using defaults to
using that class, so I'm guessing that none of the expressions are
evaluating to true.  However, the dbf for the shape seems to indicate that
this should not be the case.  The only error being thrown is the following:
Thu Jul 17 10:41:37 2003 - msSearchDiskTree(): Unable to access file.
Unable to open spatial index for /home/wcs/html/data/countries2.qix. In
most cases you can safely ignore this message, otherwise check file names
and permissions.
Thanks for your help.
System Administrator
ZedX Inc.
369 Rolling Ridge Drive
Bellefonte, PA. 16823
More information about the MapServer-users mailing list
