[Mapserver-users] Class Expression help
Nick Petersen-Bergeron
bergeron at zedxinc.com
Thu Jul 17 12:50:34 EDT 2003
Unquoting the entire expression produces an expression parser error.
At 01:08 PM 7/17/2003 -0300, you wrote:
>El jue, 17 de 07 de 2003 a las 12:22, Nick Petersen-Bergeron escribió:
>>As a followup, when I quote the column name, I get the error:
>>Thu Jul 17 11:29:04 2003 - msEvalExpression(): General error message.
>>Cannot evaluate expression, no item index defined.
>>While this error seems more pertinent, an Item Index shouldn't be necessary
>>should it?
>The whole expression shouldn't been unquoted?
><SIC> EXPRESSION [string] Three types of expressions are now supported to
>define class membership. String comparisons, regular expressions, and
>simple logical expressions. If no expression is given, then all features
>are said to belong to this class.
>String comparisons are case sensitive and are the fastest to evaluate. No
>special delimiters are necessary although string must be quoted if they
>contain special characters. (As a matter of good habit, it is recommended
>you quote all strings).
>Regular expressions function just like previous versions of MapServer.
>However, you must now delimit a regular expression using /regex/. No
>quotes should be used.
>Logical expressions allow you to build fairly complex tests based on one
>or more attributes and therefore are only available with shapefiles.
>Logical expressions are delimited by parentheses "(expression)". Attribute
>names are delimited by square brackets "[ATTRIBUTE]". These names are case
>sensitive and must match the items in the shapefile. For example:
>EXPRESSION ([POPULATION] > 50000 AND '[LANGUAGE]' eq 'FRENCH') ... The
>following logical operators are supported :
>=,>,<,<=,>=,=,or,and,lt,gt,ge,le,eq. As you might expect this level of
>complexity is slower to process.
>String comparisons and regular expressions work from the classitem defined
>at the layer level. You may mix expression types within the different
>classes of a layer.
></SIC>
>>At 05:01 PM 7/17/2003 +0200, Vincent Schut wrote:
>> >Nick,
>> >jsut a guess, but have you tried it with [LEVEL] and [DAY] single
>> quoted too?
>> >I think you always need to quote your attribute column names.
>> >Regards,
>> >Vincent.
>> >On Thursday 17 July 2003 16:50, Nick Petersen-Bergeron wrote:
>> > > I'm trying to do a class based layer structure for a map program I'm
>> > > writing. I've looked through all of the syntax examples for expressions
>> > > that I can find, but can't seem to figure out what's wrong.
>> > > I have around 20 classes in the layer. Essentially the only thing that
>> > > will differ between classes is the color.
>> > > I've included an example of one of the classes.
>> > > CLASS
>> > > EXPRESSION "(('[TEMP]' eq 'normal') AND ('[PRECIP]' eq
>> > > 'normal') AND ([LEVEL] eq 0) AND ([DAY] eq 30))"
>> > > COLOR 50 50 50
>> > > SIZE 5
>> > > NAME "normal_city"
>> > > SYMBOL "circle"
>> > > LABEL
>> > > COLOR 50 50 50
>> > > FONT arial
>> > > SIZE 12
>> > > POSITION ur
>> > > ANTIALIAS TRUE
>> > > TYPE TRUETYPE
>> > > END
>> > > END
>> > > Can anyone see a problem with this?
>> > > When I comment out a single expression, the shapefile I'm using
>> defaults to
>> > > using that class, so I'm guessing that none of the expressions are
>> > > evaluating to true. However, the dbf for the shape seems to
>> indicate that
>> > > this should not be the case. The only error being thrown is the
>> following:
>> > > Thu Jul 17 10:41:37 2003 - msSearchDiskTree(): Unable to access file.
>> > > Unable to open spatial index for /home/wcs/html/data/countries2.qix. In
>> > > most cases you can safely ignore this message, otherwise check file
>> names
>> > > and permissions.
>> > > Thanks for your help.
>>System Administrator
>>ZedX Inc.
>>369 Rolling Ridge Drive
>>Bellefonte, PA. 16823
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>><http://lists.gis.umn.edu/mailman/listinfo/mapserver-users>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>ZedX Inc.
