[Mapserver-users] Mapscript problems
Joe Smith
joe at poconogis.com
Thu Jul 17 16:34:28 EDT 2003
Thanks Vincent, one problem solved. I successfully compiled php into
/usr/local/phpcgi (where I put php.ini and php_mapscript.so). Apache loads
php as a cgi, and phpinfo() works fine, but it doesn't see my
php_mapscript.so module. I'm not sure if it's a setting in a file or if
it's compiled wrong, although I didn't get any errors. It sees the correct
php.ini file, and I changed the extension_dir to be "/usr/local/phpcgi" just
so I knew where it was looking for sure, and it still doesn't see it.
Joe
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Vincent
Schut
Sent: Thursday, July 17, 2003 11:26 AM
To: Joe Smith; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Mapscript problems
Hi Joe,
probably php actually does compile with the system-regex, but you keep using
your old version of php... The --prefix option points to the dir where php
gets installed. That means that your php cgi executable will end up in
something like /usr/local/www/php/bin/, which is probably not in your path
and also not where apache looks for to launch the php cgi executable. You
best set --prefix to something like /usr/local/phpcgi if you want to have 2
seperate version of php (probably the php that came with your linux
distribution has been installed in /usr/, and I guess you did not uninstall
it so it will be there still). After installing php in /usr/local/phpcgi (or
whatever you want, but I discourage installing anyting in directories
beneath
your webroot, it is asking for security problems!) you will have to tell
apache in its httpd.conf file that it should launch the php cgi exe for .php
(or .phpms or whatever you like) files. And of course you should have copied
the just installed php executable to your cgi-bin directory.
You can find more about this in the wiki:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerCompilation , read on
from here.
Good luck,
Vincent.
On Thursday 17 July 2003 17:04, Joe Smith wrote:
> Hi,
> I have been working with mapserver for a few weeks now without too much
> trouble, but I've run into some problems trying to get mapscript to
> compile. It runs fine without the --with-php option, but I'm looking to
add
> more functionality. I'm actually trying to get mapscript compiled in two
> places - my local linux box where i do the editing, and on the web server.
> It doesn't seem to work on either.
> Here's the specs/problem on the local box:
> Linux 9, apache 2.0.47, php 4.3.2, mapserver 3.6.6
> I know what the problem is ; php isn't compiling with
> the --with-regex=system like it should, and I don't know why. I checked
> phpinfo and the regex section didn't have anything about system. I
compile
> php like this:
> ./configure \
> --prefix=/usr/local/www/php \
> --with-config-file-path=/usr/local/www/php \
> --enable-track-vars \
> --enable-force-cgi-redirect \
> --with-regex=system \
> --with-mysql \
> --with-zlib \
> --without-ttf
> make
> make install
> cp -p php.ini-recommended /usr/local/www/php/php.ini
> I tried removing config.cache like some of the posts suggested (and make
> clean), but it did not work. I'm still getting familiar with linux/unix
so
> I wouldn't really know where to look if it was using some old version of a
> file in the compile.
> Joe
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
