[Mapserver-users] Lambert Projection for Europe
Maul, Andreas-Alexander
Andreas.Maul at bgr.de
Fri Jul 18 04:42:43 PDT 2003
Steffen,
You can find the parameter list for the Lambert Conformal Conic
Projection (lcc) at
http://www.remotesensing.org/geotiff/proj_list/lambert_conic_conformal_2
sp.html
Put the appropriate projection parameters for the resulting projection
in the general part of the map file, e.g.:
PROJECTION
"proj=lcc"
"ellps=wgs84"
"lat_1=30n"
"lat_2=60n"
"lat_0=0n"
"lon_0=20e"
"x_0=0" # offset x in meters, e.g. to avoid negative values
"y_0=0" # offset y
END
(values are only suggestions/examples, choose yourself appropriate
numbers) and specify the original projection parameters (i.e. geographic
coordinates) in the layer sections:
PROJECTION
"proj=latlong"
"ellps=wgs84"
END
Regards,
Andreas
More information about the MapServer-users
