[Mapserver-users] Layer status problem and reference map problem..
AMC Story
s9646183 at sms.ed.ac.uk
Fri Jul 18 11:46:34 EDT 2003
Hi there,
I've got a couple of questions which I think must be fairly straight-forward
but I can't seem to figure them out myself.....
Firstly, I've set up some checkboxes in the HTML interface which should allow
users to turn certain layers on and off. I have a couple of layers that are
always on (i.e. set to DEFAULT in the map file), and a couple of others which
are set to OFF in the map file, but which the user can select to be turned on.
The selected layers are passed with the URL and populate an array called
@layers. I've then used the following code to update the status of these
layers:
##Turn on appropriate layers
foreach $layer (@layers){
$current_layer = $current_map->getLayerByName('$layer');
$current_layer->{status} = $mapscript::MS_ON;
I've printed the status to the screen and for each layer that was selected, the
status was updated to "1" as I expected.
The map is then drawn as follows:
#draw and save main map to PNG
$image = $current_map->draw();
$image->saveImage($image_path.$image_id,$mapscript::MS_PNG,
$current_map->{transparent}, $current_map->{interlace}, 0);
However, this map only displays the layers that were set as "DEFAULT" in the
map file, and the newly-updated "on" status for the other layers seems to be
ignored. Do I have to do something else to get these layers to be displayed?
Also, once the main map has been created, I then create a reference map like so:
#Create reference map image
$ref_img = $current_map->drawReferenceMap();
$ref_img->saveImage($image_path.$ref_image_id,$mapscript::MS_PNG,
The problem here is that the reference map often doesn't update itself, which
would obviously be quite disconcerting for the user. The reference map can be
made to update if you click on the browser's refresh/reload button, but surely
this shouldn't be necessary?
Any ideas would be great.
Thanks,
Ali
