[Mapserver-users] PHPMapscript
Chip Hankley
Chip.Hankley at rmtinc.com
Fri Jul 18 18:05:07 EDT 2003
Ryan,
For some reason, the mapscript DLL perceives your PHP installation as NOT being CGI. I have no idea why it might be doing this, but here are some things to try.
1) re-install PHP. DO NOT use the installer. Simply follow the "install by hand" method of putting the PHP subfolders in a directory (c:\php works well) and configuring the PHP.ini file. There are pretty explicit instructions in the PHP manual on how to do this.
2) MAKE SURE that the version of the PHP_MapScript DLL you are using matches the version of PHP that you are using.
3) MAKE SURE that the requried DLLs on which MapScript relies have been installed.
Outside of that, I'm clueless.
Chip
Outgoing messages, along with any attachments, are scanned for viruses at RMT prior to sending.
NOTICE--This email may contain confidential and privileged information
for the sole use of the intended recipient. Any review or distribution
by others is strictly prohibited. If you are not the intended recipient,
please contact the sender immediately and delete all copies.
