[Mapserver-users] rubber sheeting
Jan Hartmann
jhart at frw.uva.nl
Sat Jul 19 06:51:48 EDT 2003
Yes, that is the answer. I hadn't realized that it was done by
triangulation and that morphing is just another name for rubber
sheeting. Both are very well known technologies, I just hadn't made the
link to GIS terminology. Gives me quite a lot of good technical
pointers. If anyone knows free software or source code in these two
areas that could be easily transferred to GIS, please let me know. I
could try to implement it in GRASS or GDAL
Thanks Franck, Norman
Jan
Franck Martin wrote:
> Many raster software offer polynomial rectification which highly
> inadequate in most of cases today. Rubber Sheeting is the answer and the
> correct term in GIS, and as described below it is based on a
> triangulation of the map to be modified..
> The difference between polynomial and rubber sheeting is that rubber
> sheeting needs more ground control points.
> GRASS does not offer rubber sheeting, it is a pity as I don't know any
> free software that offers it.
> I guess the algorithm for rubber sheeting is well known or known also
> under the name morphing.. A google search should give some results here...
> Cheers
> On Sat, 2003-07-19 at 04:43, Norman Vine wrote:
>>/Jan Hartmann writes:
>>> The problem is that AFAIK all these rectifying routines are computed
>>> globally. You can use of course a higher order polynomial, but even so
>>> the placement of every control point will affect the whole map.
>>> Moreover, you can't use very high polynomials and too many control
>>> points. What I am looking for is something that will do *local*
>>> transformations based on nearby control points, and stretch the results
>>> together some way. Those old maps are generally correct on small
>>> subregions, but the subregions fit in no way together. There is
>>> certainly no numerical soluton for it.
>>Good question,
>>I don't think I have ever thought about 'locally adaptive' rubber sheeting.
>>Probably easiest to do by separating out the U and V correction
>>A 'simplistic' method might be to make two countour 'grids', for testing
>>purposes you could use simple triangulated surfaces, where 'Z' was the
>>displacement in X or Y respectively of each control point. Then by
>>queryng the grids by the original {X,Y} you would get a {U,V} offset by
>>interpolation, that can be used to determine the new coordinates.
>>One trick here is that the new image wants to be constructed by triangles
>>and not points, think texture mapping
>>< tough todo with ASCII >
>>HTH
>>Norman
>>_______________________________________________/
> Franck Martin <franck at sopac.org <mailto:franck at sopac.org>>
> SOPAC
