[Mapserver-users] gdal error
Frank Warmerdam
warmerdam at pobox.com
Sat Jul 19 06:34:56 PDT 2003
Devrim Catak wrote:
> I'm try to install mapserver under Suse8.2 Pro. I get error message about -gdal option, it says that the path I have
> provided for gdal is not executable.("usr/lib/gdal is not executable" exactly..)I was certain about configuring gdal
> properly but should look for a specific message in config logs of gdal? Thanks in advanc Devrim
Devrim,
You should be passing the path to the gdal-config script. Under normal
conditions this would be installed in /usr/local/bin.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
