[Mapserver-users] rubber sheeting
Paul Ramsey
pramsey at refractions.net
Sat Jul 19 11:51:55 EDT 2003
The JUMP/JCS toolkit in Java land has some rubber sheeting built into
it. We never implemented full thin-plate spines (one of our advisors
favourite algorithms) but there is some good local warping in there.
P.
On Saturday, July 19, 2003, at 06:10 AM, woodbri at swoodbridge.com wrote:
> Jan,
> I think section 3.3 is the algorithm you want at:
> http://www.hammerhead.com/thad/morph.html
> It is based on lines not points, but when you read the algorithm it
> will make sense.
> -Steve W.
> On 19 Jul 2003 at 12:51, Jan Hartmann wrote:
>> Yes, that is the answer. I hadn't realized that it was done by
>> triangulation and that morphing is just another name for rubber
>> sheeting. Both are very well known technologies, I just hadn't made
>> the link to GIS terminology. Gives me quite a lot of good technical
>> pointers. If anyone knows free software or source code in these two
>> areas that could be easily transferred to GIS, please let me know. I
>> could try to implement it in GRASS or GDAL
>> Thanks Franck, Norman
>> Jan
>> Franck Martin wrote:
>>> Many raster software offer polynomial rectification which highly
>>> inadequate in most of cases today. Rubber Sheeting is the answer and
>>> the correct term in GIS, and as described below it is based on a
>>> triangulation of the map to be modified..
>>> The difference between polynomial and rubber sheeting is that rubber
>>> sheeting needs more ground control points.
>>> GRASS does not offer rubber sheeting, it is a pity as I don't know
>>> any free software that offers it.
>>> I guess the algorithm for rubber sheeting is well known or known
>>> also under the name morphing.. A google search should give some
>>> results here...
>>> Cheers
>>> On Sat, 2003-07-19 at 04:43, Norman Vine wrote:
>>>> /Jan Hartmann writes:
>>>>> The problem is that AFAIK all these rectifying routines are
>>>>> computed globally. You can use of course a higher order
>>>>> polynomial, but even so the placement of every control point will
>>>>> affect the whole map. Moreover, you can't use very high
>>>>> polynomials and too many control points. What I am looking for is
>>>>> something that will do *local* transformations based on nearby
>>>>> control points, and stretch the results together some way. Those
>>>>> old maps are generally correct on small subregions, but the
>>>>> subregions fit in no way together. There is certainly no numerical
>>>>> soluton for it.
>>>> Good question,
>>>> I don't think I have ever thought about 'locally adaptive' rubber
>>>> sheeting.
>>>> Probably easiest to do by separating out the U and V correction
>>>> A 'simplistic' method might be to make two countour 'grids', for
>>>> testing purposes you could use simple triangulated surfaces, where
>>>> 'Z' was the displacement in X or Y respectively of each control
>>>> point. Then by queryng the grids by the original {X,Y} you would
>>>> get a {U,V} offset by interpolation, that can be used to determine
>>>> the new coordinates. One trick here is that the new image wants to
>>>> be constructed by triangles and not points, think texture mapping
>>>> < tough todo with ASCII >
>>>> HTH
>>>> Norman
>>>> _______________________________________________/
>>> Franck Martin <franck at sopac.org <mailto:franck at sopac.org>>
>>> SOPAC
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
