[Mapserver-users] MS 4 beta2, problems with queryByPoint and PostGIS
Yewondwossen Assefa assefa at dmsolutions.ca
Mon Jul 21 16:41:57 PDT 2003
Hi There,
 I have placed a new version of php_mapscript_40.dll  (php4.3.2, latest
mapserver 4.0 ) at http://www2.dmsolutions.ca/tmp/php_mapscript_40.dll
that should correct the crah for the querybypoint. Can you give it a try
and let me know (I will put a full distribution sometimes this week on
the usual download site).
 I am not sure though if It solves the second problem you mentionned
about "some records were not returned properly". Could you give need
more information on this so It will be easier  to identify the problem.
Later,
Armin Burger wrote:
>Hello,
>I wonder if anybody else ran into the same problem with the current
>version 4 beta2 and the PHP/Mapscript method 'queryByPoint'. Applying
>this method on a map object with active PostGIS layers crashes the
>php.exe on Windows, and under Linux one just gets a server error. A
>similar problem happened when using 'queryByRect'. Here PHP not always
>crashed but some records were not returned properly (or maybe only the
>last one).
>I tested the functions with the Win 4 beta 2 executable from 11 July
>(from DM Solutions) and the beta 2 tar package compiled under Linux. The
>version 4 beta 1 was working fine with regard to PostGIS. Any ideas what
>happened?
>Armin
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the MapServer-users mailing list
