[Mapserver-users] Possible to use a 'event theme' with mapserver?
blackmail at snafu.de
Tue Jul 22 04:32:42 EDT 2003
--------------060205030708030900010304
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
Content-Transfer-Encoding: 7bit
>Would like to display points coming from a dbase File with x and y
> coordinates. In ArcView this is called an 'event theme'. Is this
> possible with Mapserver and Dbase-Table?
"you could use mapscript to create a new layer from your dbase file
on-the-fly, and add this layer to the currently displayed layers."
Did anyone try this with mapscript & Java?
Or is it possible to work with a dynamic layer resulting from records (x,y ) of a dBase table?
Content-Type: text/html; charset=ISO-8859-2
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-2">
<title></title>
</head>
<body>
<pre wrap="">
<span class="moz-txt-citetags">> </span>coordinates. In ArcView this is called an 'event theme'. Is this
<span class="moz-txt-citetags">> </span>possible with Mapserver and Dbase-Table?
</pre>
<pre wrap=""><!---->
</pre>
</body>
</html>
--------------060205030708030900010304--
