[Mapserver-users] Problem setting up direct URLs when using MapScript
Lowell Filak
lfilak at medinaco.org
Tue Jul 22 10:44:39 EDT 2003
What does the "<img src=..." part of the returned page look like?
Lowell
The following message was sent by AMC Story <s9646183 at sms.ed.ac.uk> on
Tue, 22 Jul 2003 15:03:48 +0100 (BST).
> Hi there,
> My problem is that I've set up a user interface to my application
using perl
> MapScript. The script utilises a form that passes back variables such
as the
> current map extents, previous map extents, mouse click locations,
modes (ie.
> pan north, zoomin, previous extent etc), active layers and so on. I
then use
> MapScript to manipulate these variables, set the new extents and
active layers
> accordingly and then redraw the map.
> So, the user is first presented with a screen that lists all the
features of
> interest (i.e. all the point objects in my shapefile). The user can
then click
> on the url of each feature to go to the map interface page and see a
map that
> is zoomed in to that point. The user can also click on an image on
the opening
> page which submits a form with the hidden variable "mode" set to
"full_extent",
> so that they see the whole world map with all the features displayed.
> The problem is, that when you click on the url (which looks like this...
> <a
href="http://file_path/script?lon=123.64&lat=-0.51&mode=each_feature">)
the
> variables are passed and the script runs. The script then works out
the extent
> of the new map based on these variables and a new map should be
created with
> this extent (ie the extents for $current_map are set to their zoomed
in values,
> and then the $current_map->draw method draws the map). However, to
see the
> zoomed in map, you have to manually refresh the browser, or put in a
line to
> the script which does this automatically for you. Otherwise, the map
is drawn
> as if the extent values haven't actually been changed from those in
the map
> file. Can anyone see why this might be the case? I've printed out
the extents
> of the map object just before it gets drawn, and they definately have
been
> updated, but the map object that is drawn doesn't seem to reflect this..??
> Sorry if this is a really long-winded e-mail ;)
> Many thanks for any thoughts,
> Ali
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
