[Mapserver-users] Problem with LINEITEM and CLASS NAME
Roger Truesdale
ROGERT at gwm.sc.edu
Tue Jul 22 11:11:42 EDT 2003
I am running mapserv 3.6.6 with the following map that is listed below.
Note the two lines marked by #-- in the TOWER layer. One is for the
layer LINEITEM and the other for the class NAME.
When BOTH of these lines are commented out, a map of county boundries
appears with green circles for the tower locations.
This part works fine, but I want to use the TowerId field values from
the dbf file as labels for the tower locations. When I attempt to do
this by uncommenting only the LINEITEM line, I just get a blank screen
coming back with no error messages. I checked that the LINEITEM value
TOWERID has the same case as in the dbf table. I also noticed that if I
leave the LINEITEM line commented out and uncomment the class NAME line,
then I also get a blank screen back. Can anyone see what I am doing
wrong or what I may be missing?
Thanks.
-------------------------------------- MAP FILE
# Start of map file
NAME MAPSERV
STATUS ON
SIZE 600 600
FONTSET symbols/fonts/fonts.list
#SHADESET symbols/shade.sym
#MARKERSET symbols/marker.sym
#LINESET symbols/line.sym
SYMBOLSET symbols/symbols_ms34.sym
EXTENT 1292500.875 77778.96875 2746368.25 1233433.875
#EXTENT 1223954.55020386 62738.1920192846 2817302.34231788
1247690.0222657
UNITS FEET
SHAPEPATH "D:\Inetpub\wwwroot\test\ShapeData"
IMAGECOLOR 255 255 255
# Start of web interface definition
WEB
HEADER "mapserv_header.html"
TEMPLATE "mapserv.html"
FOOTER "mapserv_footer.html"
MINSCALE 1000
MAXSCALE 15500000
IMAGEPATH "d:\inetpub\wwwroot\test\temp\"
IMAGEURL "/test/temp/"
# LOG "D:\Inetpub\test\mapserv.log"
# LOG "mapserv.log"
END
QUERYMAP
SIZE 75 75
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
#REFERENCE
# IMAGE Graphics/reference.gif
# EXTENT 1223954.55020386 62738.1920192846 2817302.34231788
1247690.0222657
# SIZE 50 50
# COLOR -1 -1 -1
# OUTLINECOLOR 255 0 0
#END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE Small
COLOR 5 10 100
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 000 000 000
LABEL
COLOR 000 000 000
SIZE Small
END
STYLE 1
SIZE 20 2
COLOR 000 000 000
UNITS FEET
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
# Start of layer definitions
LAYER
NAME COUNTY
TYPE POLYGON
DATA county
STATUS DEFAULT
CLASS
SYMBOL 3
SIZE 4
OUTLINECOLOR 128 128 128
COLOR 255 255 128
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
POSITION AUTO
SIZE medium
PARTIALS TRUE
BUFFER 2
END # LABEL OBJECT
END # CLASS OBJECT
HEADER "county_detail_header.html"
FOOTER "county_detail_footer.html"
QUERY
TEMPLATE "county_detail.html"
END
END # end of layer object
# Start of Tower Layer
LAYER
NAME TOWER
TYPE Point
STATUS DEFAULT
DATA TOWER
#-- LABELITEM "TOWERID"
CLASSITEM "SYMBOL"
CLASS
EXPRESSION /1/
#-- NAME "TOWERS"
SYMBOL 13
SIZE 11 # legend symbol size
COLOR 000 128 000 # legend symbol color - green
LABEL
COLOR 0 0 0
POSITION AUTO
SIZE small
PARTIALS TRUE
BUFFER 2
END
END # CLASS
END #LAYER
END # End of Map File
Roger Truesdale
Interactive Site Architect
eBusiness Solutions (f.k.a. i2Media)
Contractual Services Group
Usc Computer Services
1244 Blossom Street, Columbia, SC 29208
Voice: (803) 777-7366 | (803) 777-1900 (fax)
rogert at gwm.sc.edu | http://i2alliance.sc.edu
