[Mapserver-users] MS 4 beta2, problems with queryByPoint andPostGIS
Yewondwossen Assefa
assefa at dmsolutions.ca
Wed Jul 23 09:58:48 EDT 2003
--------------030205010007010908030007
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I have tried thios with a test data that I had and I was woring properly
for me. I used variable name (as well as statis text) to access the
values of the shape.
I do not really know what is wrong in your case (make sure that the
field names are valid using print_r($qShape->values);
I am ccing the list in case maybe someone has the same pb/idea.
Later
Armin Burger wrote:
>Assefa,
>I had a look at the function that causes the problem under MS on Windows.
>The query itself is executed with
>$selrect = ms_newrectObj();
>$selrect->setextent($minx_sel_geo, $miny_sel_geo, $maxx_sel_geo,
>$maxy_sel_geo);
>@$queryMap->queryByRect($selrect);
>$selrect->free();
>I use something like the following to print out the results:
>1 $numResults = $qLayer->getNumResults();
>2 if ($numResults > 0) {
>3
>4 // ONE ROW IN TABLE FOR EACH RECORD
>5 for ($iRes=0; $iRes < $numResults; $iRes++) {
>6 $qRes = $qLayer->getResult($iRes);
>7 $qShape = $qLayer->getShape($qRes->tileindex,$qRes->shapeindex);
>8
>9 printf("<TR>");
>10 // Print all OTHER COLUMNS from SHAPE
>11 for ($iField=0; $iField < sizeof($selFields); $iField++) {
>12 $fldName = $selFields[$iField];
>13 $fldValue = $qShape->values[$fldName];
>14 printf("<td>$fldValue</td>");
>15 }
>16 printf("</TR>\n");
>17
>18 $qShape->free();
>19 }
>20 $qLayer->close();
>21 }
>As I mentioned in my last mail queryByPoint works fine. I can also
>execute the 'queryByRect' and just print out the number of records. The
>errors occur only if I want to print out the values for all found records
>with the function above.
>When I comment out the lines 7 and 18 and in line 13 just define a fix
>string as value then everything works ok. So the 'getShape' method seems
>to cause problems for results with plenty of records. I tested it with 2
>different postgis versions, one on Linux, the other one under Win/Cygwin.
>The error occured for both.
>To make things even stranger, the error did *not* show up on a Linux
>system and new compiled MS from nightly build (date: 22 July) with the
>new mappostgis.c file. Here I used the same Postgis database as with the
>test on Windows.
>Armin
>>Hi There,
>> I have placed a new version of php_mapscript_40.dll (php4.3.2, latest
>>mapserver 4.0 ) at http://www2.dmsolutions.ca/tmp/php_mapscript_40.dll
>>that should correct the crah for the querybypoint. Can you give it a
>try
>>and let me know (I will put a full distribution sometimes this week on
>>the usual download site).
>> I am not sure though if It solves the second problem you mentionned
>>about "some records were not returned properly". Could you give need
>>more information on this so It will be easier to identify the problem.
>>Later,
>>Armin Burger wrote:
>>>Hello,
>>>I wonder if anybody else ran into the same problem with the current
>>>version 4 beta2 and the PHP/Mapscript method 'queryByPoint'. Applying
>>>this method on a map object with active PostGIS layers crashes the
>>>php.exe on Windows, and under Linux one just gets a server error. A
>>>similar problem happened when using 'queryByRect'. Here PHP not always
>>>crashed but some records were not returned properly (or maybe only the
>>>last one).
>>>I tested the functions with the Win 4 beta 2 executable from 11 July
>>>(from DM Solutions) and the beta 2 tar package compiled under Linux.
>The
>>>version 4 beta 1 was working fine with regard to PostGIS. Any ideas
>what
>>>happened?
>>>Armin
>>>_______________________________________________
>>>Mapserver-users mailing list
>>>Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body>
for me. I used variable name (as well as statis text) to access the values
of the shape.<br>
I do not really know what is wrong in your case (make sure that the field
names are valid using print_r($qShape->values);<br>
<br>
I am ccing the list in case maybe someone has the same pb/idea.<br>
<br>
Later<br>
<br>
Armin Burger wrote:<br>
<blockquote type="cite"
cite="mid20030722214222.ROXQ4247.viefep16-int.chello.at at libero.it">
<pre wrap="">Assefa,
$maxy_sel_geo);
$selrect->free();
3
8
9 printf("<TR>");
15 }
17
18 $qShape->free();
19 }
21 }
test on Windows.
Armin
</pre>
<blockquote type="cite">
<pre wrap="">Hi There,
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap=""> I have placed a new version of php_mapscript_40.dll (php4.3.2, latest
mapserver 4.0 ) at <a class="moz-txt-link-freetext" href="http://www2.dmsolutions.ca/tmp/php_mapscript_40.dll">http://www2.dmsolutions.ca/tmp/php_mapscript_40.dll</a>
</pre>
</blockquote>
<pre wrap=""><!---->try
</pre>
<pre wrap="">and let me know (I will put a full distribution sometimes this week on
</pre>
</blockquote>
</pre>
<pre wrap="">Later,
</pre>
</blockquote>
</pre>
<pre wrap="">Armin Burger wrote:
</pre>
</blockquote>
</pre>
<pre wrap="">Hello,
last one).
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->The
</pre>
<pre wrap="">version 4 beta 1 was working fine with regard to PostGIS. Any ideas
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->what
</pre>
<pre wrap="">happened?
Armin
<a class="moz-txt-link-abbreviated" href="mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.gis.umn.edu</a>
<a class="moz-txt-link-freetext" href="http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</a>
</pre>
</blockquote>
</blockquote>
</pre>
<pre wrap="">--
Assefa Yewondwossen
Software Analyst
</pre>
</blockquote>
</pre>
<pre wrap="">Email: <a class="moz-txt-link-abbreviated" href="mailto:assefa at dmsolutions.ca">assefa at dmsolutions.ca</a>
<a class="moz-txt-link-freetext" href="http://www.dmsolutions.ca/">http://www.dmsolutions.ca/</a>
</pre>
</blockquote>
</pre>
<pre wrap="">Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
</pre>
</blockquote>
</pre>
</blockquote>
<br>
<pre class="moz-signature" cols="$mailwrapcol">--
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
</pre>
<br>
</body>
</html>
--------------030205010007010908030007--
