[Mapserver-users] display by scale.
Fawcett, David
David.Fawcett at state.mn.us
Wed Jul 23 10:29:26 EDT 2003
You want to set values for MINSCALE and MAXSCALE in the LAYER object.
More information can be found in the documentation: http://mapserver.gis.umn.edu/doc/mapfile-reference.html#layer
David.
> From: > ¦¿©v®i[SMTP:heihachi.cv90g at nctu.edu.tw]
> Sent: Wednesday, July 23, 2003 9:21 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] display by scale.
> Dear All
> I wonder if mapserver can display certain layer by the scale of current map.
> For example, when scale is bigger than 1/500 the map showes
> layer A,when scale is smaller than 1/500 then the map hides layer
> A.
> Is it to edit the map file to achieve?If yes, what variable should I modify?
> Thanx!!!
