[Mapserver-users] Using MapServer as a general graphing engine
W. Steph chewbizz at hotmail.com
Tue Jul 29 00:58:57 PDT 2003
Just a thing :
>But as far as I know there is no possibility to include
>externally produced images and merge them on top of the map image.
There's a very simple way !
Just don't display the image with php, but use a java applet instead. Then,
you'll can be able to do whatever you waqnt with the image, including adding
other images. The only problem is that some colors can change a bit with
some image types (I think png in an applet hasn't good colors but this may
have change in latest versions).
I'm using this method in order to let the user draw new polygon and
multipoint layers on the map (and then I use geoserver WFS to send the data
to the PostGis database) and it works very well.
Adding charts and other dynamically generated images on a map (assuming you
can calculate the good coordinates where to display the image) isn't a
problem using java !
I think you'll be able to test my java-based web application about the end
of september, if you want to see it up and running :p
Steph
_________________________________________________________________
MSN Messenger 6  http://g.msn.fr/FR1001/866 : plus de personnalisation, plus
de fun pour vous et vos amis…
More information about the MapServer-users mailing list
