[Mapserver-users] ms_newMapObj in latest 4.0 changed?
Daniel Morissette
morissette at dmsolutions.ca
Tue Jul 29 09:59:54 EDT 2003
Vinko Vrsalovic wrote:
> PHP Warning: [MapServer Error]: msEvalRegex(): String (/tmp/map) failed
> expression test.
> in /var/www/html/draw.php on line 3
> PHP Warning: Failed to open /tmp/map file map in /var/www/html/draw.php on line 3
> PHP Fatal error: Call to a member function on a non-object in /var/www/html/draw.php on line 4
That's because the mapfile filename doesn't match the MS_MAPFILEPATTERN
regular expression. In this case you're probably missing the ".map"
extension.
There's a little bit of info on MS_MAPFILEPATTERN in the migration guide
at http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MigrationGuide
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
