[Mapserver-users] WMS GetFeatureInfo
Howard Mark
MHoward at spaceimaging.com
Wed Jul 30 16:02:23 EDT 2003
Thanks for asking, this is a great list!
Actually I solved it.
Parameter is FEATURE_COUNT in WMS call.
The default value must be one?
BTW another getfeatureinfo TTK (thing to know)
You set the radius for getfeatureinfo in the map file instead of in the URL
(&RADIUS=10).
Parameters are (e.g.):
TOLERANCEUNITS pixels
TOLERANCE 10
To get features in an extent, I use 500 pixels, the extent as the bbox --
and intersect the result against my extent.
Mark
-----Original Message-----
From: Arnulf Christl (CCGIS) [mailto:arnulf.christl at ccgis.de]
Sent: Wednesday, July 30, 2003 12:01 PM
To: Howard Mark; mapserver-users at lists.gis.umn.edu
Subject: AW: [Mapserver-users] WMS GetFeatureInfo
Hi Mark,
seems like nobody wants to answer your question. I cannot either, because
the GetFeatureInfo works fine with me. Can you specify cour problem in more
detail?
Cheers, Arnulf.
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Howard
Mark
Gesendet: Montag, 28. Juli 2003 16:54
An: mapserver-users at lists.gis.umn.edu
Betreff: [Mapserver-users] WMS GetFeatureInfo
Can anybody tell me how to get multiple feature records using the WMS
request=GetFeatureInfo?
This is NOT using the map query template!
I'm only getting one record now when querying a layer containing many
polygons under the selected point.
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
