[Mapserver-users] WMS'ifying a MAP file and Reprojection OTF (shp, postgis & tiff)
Julia Harrell
julia.harrell at ncmail.net
Wed Jul 30 22:24:52 EDT 2003
Hello Mapsever Experts
I'm inexperienced with Mapserver & not an expert at WMS, so I would
appreciate some enlightenment from the list.
We are trying to add a Mapserver WMS map service to regional testbed
for a National Map viewer. It is an ArcIMS viewer (bad, I know) but
that shouldn't matter a whole lot. We do have 1 county participant
already using Mapserver, and we are trying to WMS'ify a copy of their map
file. Basically we think this just means adding projection and wms metadata
to a copy of their existing mapfile, but there are issues with reprojecting
on the fly that we need advice about.
They are running on some variety of Linux :
MapServer version 3.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
We can get Mapserver to send a blank map when we issue a WMS GETMAP URL
request
in a browser, but I suspect we have a problem in our projection information,
since none of the layers are drawing.
All of the data (shapefile & PostGIS) is in EPSG:32019 (NC State Plane,
units of Feet,
NAD 27 Datum). The viewer is only going to be requesting data from all
participating
map servers in EPSG:4326 (Lat/Longs - WGS84 datum), so this is the only SRS
we
care about the map service outputting map images in.
>From my archive searching, I think I need to include a projection section
for
each layer as well as in the main part of the MAP File. I need clarification
on
these somewhat intertwined issues:
A) do I use the EPSG code in the MAP section for the
SRS I want the maps output in? I want output in EPSG:4326,
so if this is the case, I assume my extents & units should be in
decimal degrees. Also, should we use the extents of the county
or use extents as far out as we want the Mapserver data to
be visible? Ideally we'd want to be able to view some of
the layers at a regional level (things like ETJs & City Limits).
B) do I use the EPSG code in each LAYER section for the
SRS the data is actually stored in? I have data in EPSG:32019.
If I should be specifying the output SRS here too, then where
(and how) do I tell Mapserver what the actual SRS is? It doesn't
read shapfile .prj files, so how will it know?
If either A or B (or both) is not true, then I guess I just need
someone to spell-it-all-out :)
C) What do we need to do to correctly handle the datum transformation?
I noticed the March 2003 discussion about PROJ support not
necessarily meaning you have support for datum shifts. Does this
handle only NAD27<->NAD83 datum shifts? I could certainly use
an example of how we should specify the datum transformation from
NC State Plane (feet) NAD27 to WGS84 lat/longs for our output maps,
if just specifying the EPSG SRS code is not enough.
D) We also need advice about raster warping. One of the layers the
county wants to serve to the NC Natl Map viewer is a raster layer
(tiles of TIFF orthophotos). The raster how-to wiki page says:
"However, raster warping is currently only supported for images
accessed through GDAL, not for the other builtin formats."
There was no example, so this is actually of limited help to a newbie.
Can someone please point me to a well-annotated example of what a MAP
file should look like when reprojecting imagery with GDAL, instead of
the
(normally) built-in libtiff? Do we have to do anything differently,
other than not have libtiff support enabled? I did read this post:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0301/msg00459.html
How do you tell if your build of Mapserver was compiled without libtiff?
Is it as simple as not seeing INPUT=TIFF on the -v command line output?
Luckily, this county is using Linux, so recompilation (if needed)
*may* be within the skill set of their contractors.
I realize this is a lot of questions, but I haven't had any success finding
the
answers we need. Eternal thanks to all who will respond with patience for
the
extremely confused :)
Sincerely,
Julia Harrell
NC CGIA
