[Mapserver-users] WMS Client on IIS with MS_MAPFILE variable problem
Sean Gillies
sgillies at frii.com
Thu Jul 31 12:17:13 EDT 2003
On Thursday, July 31, 2003, at 09:36 AM, David Graham wrote:
> Hi everyone:
> Here is a tricky one, perhaps someone has solved this problem. I am
> no IIS expert, so there may yet be a simple solution to this.
> We have some WMS serviers running on Linux and they work fine. I have
> hidden the map file with a shell script as suggested in the WMS Server
> documentation.
> [root at commerce1 cgi-bin]# more i3_demo
> #! /bin/sh
> MS_MAPFILE=/var/www/wms.i3.com/mapfiles/i3demo.map
> export MS_MAPFILE
> /var/www/wms.i3.com/bin/mapserv3.7
> And it works great.
> I now need to perform the same functionality on Windows 2000 using
> IIS. I searched around to see if I could set an environment variable
> to be associated with a given script(exe) but could not find a
> reference or dialog box to set anything.
> I then tried windows scripting. I used cscript.exe to execute the
> following jscript script.
> [dave at solar dave]$ more i3image.js
> var WshShell = WScript.CreateObject("WScript.Shell");
> var WshSysEnv = WshShell.Environment("SYSTEM");
> WshSysEnv.Item( "MS_MAPFILE" ) =
> "N:\\wms_data\\mapfiles\\wms1\\i3_Imagery_wms_service.map";
> WshShell.Run( "C:\\Inetpub\\wwwroot\\wms\\wmsserver.exe", 0, true );
> Then I set the IIS to map an empty file I labled wms.i3image to
> C:\WINNT\cscritpt //Nologo <pathto>\i3image.js
> After setting up some permissions, this executed but I have no results.
> The problem is that the script spawns a new shell and send the output
> to that shell which is then not related back to IIS.
> It also accured to me that the new shell might not even have the
> inherited the CGI environment, but I have not tested that either.
> So my question is has anyone cracked this problem? I know I could
> probably do it in perl or python, but I would rather avoid putting
> another package on the system just for a script this small. This is
> supposed to be the first in a bank of machines that will run only
> Mapserver WMS services with no other applications installed. The idea
> is to minimize the amount of software and thus reduce the degredation
> of the Windows system.
> By the way Windows is a prerequisit since we will be serving up a lot
> of data that is compressed in ECW format.
> So if anyone can give me suggestions on how to make this work with
> Windows 2000 provided technology I would greatly apreaciate it.
> Thanks
> Dave Graham
Dave, did you mean to type "WMS Server" in your subject?
Have you thought about setting up a cascading WMS server on Linux?
In your linux mapserver's map file, define a client connection to
your IIS WMS mapserver. This may not be the highest performance
solution, but it'll get you online without advertising your
mapfile.
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
