[Mapserver-users] Proj problems
Gerry Creager
gerry.creager at tamu.edu
Thu Jul 31 17:28:57 EDT 2003
This is a multi-part message in MIME format.
--------------060506070601010802090905
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
OK, I'm pretty much at my wits' end. I've tried looking at this on a
time-available basis, and I'm just not getting it.
A mapserv -v yields the following:
[root at mesonet cgi-bin]# ./mapserv -v
MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=GD2_RGB INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
PROJ support is there, so it should allow me to specify a projection
section, either with the EPSG shortcut or the long way, with everything
specified. I've tried that and what I end up with is essentially a
blank screen...
If someone's got suggestions, great. The mapfile is attached. I'll
keep looking at it, but it's looking like my hair's on fire and I can't
get it put out...
Thanks in advance,
Gerry
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020
FAX: 979.847.8578 Pager: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
name="mesonet.map"
Content-Disposition: inline;
filename="mesonet.map"
### This map file is used to control the Texas Mesonet Mapserver
### Luke Wallace, Fall 2002 (Thanks, Luke!)
### Change Log
### 2003-07-13: Changed Layer 'buffer' to reduce number of
### overlapping points and enhance readability
NAME TxMeso
STATUS ON
SIZE 700 700
#SIZE 650 650
#EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
EXTENT -106.8 25.8 -93.52 36.4
UNITS DD
SHAPEPATH "/var/www/mesonet/texas/data"
IMAGECOLOR 255 255 255
FONTSET "fonts.list"
SYMBOLSET "symbols.sym"
# you may need to change this to match your MapServer build
IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter discussion
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
#PROJECTION
# proj=latlong
# ellps=GRS80
# datum=NAD83
#END
PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:4267" #nad 27 lat/long unprojected
"init=epsg:32039" #Texas Central LCC NAD83
END
#PROJECTION
# "proj=longlat"
# "ellps=clrk66"
# "no_defs"
# "no_defs"
#END
# Start of web interface definition (including WMS enabling metadata)
WEB
# HEADER mesonet_header.html
TEMPLATE "mesonet1.html"
FOOTER mesonet_footer.html
# ERROR "../index.php"
MINSCALE 50000
MAXSCALE 50000000
IMAGEPATH "/var/www/mesonet/tmp"
IMAGEURL "/var/www/mesonet/tmp"
METADATA
WMS_TITLE "MapServer Texas"
WMS_ABSTRACT "Realtime Weather Interface"
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://mesonet.tamu.edu/index.php"
WMS_SRS "EPSG:32039"
END
END
#QUERYMAP
# SIZE 200 200
# STATUS ON
# STYLE HILITE
# COLOR 255 0 0
#END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 150 4
COLOR 255 255 255
# UNITS MILES
UNITS kilometers
INTERVALS 4
TRANSPARENT TRUE
STATUS TRUE
END
# Legend
LEGEND
STATUS ON
POSTLABELCACHE ON
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 5 5 END
FILLED FALSE
END
SYMBOL
NAME 'pwvcircle'
TYPE ELLIPSE
FILLED TRUE
POINTS 5 5 END
END
# Start of layer definitions
LAYER
SIZEUNITS pixels
NAME rain
TYPE line
DATA rain_dd
STATUS false
CLASS
NAME 'Rainfall Contours'
COLOR 25 20 200
END # CLASS
END # LAYER
# Roads
LAYER
SIZEUNITS pixels
PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
"init=epsg:32039"
END
NAME roads
TYPE line
DATA usdotrds
STATUS false
CLASS
NAME 'Roads'
COLOR 0 0 0
END
END # LAYER
# Lakes and Rivers
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME rivers
TYPE polygon
DATA hydgen
STATUS false
CLASS
NAME 'Lakes & Rivers'
TEMPLATE "lakes.html"
COLOR 100 125 225
END
HEADER "lakes_header.html"
FOOTER "lakes_footer.html"
TOLERANCE 3
END # LAYER
# Radar Layer
LAYER
NAME radar
SIZEUNITS pixels
PROJECTION
"proj=longlat"
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
END
DATA "tmp/radar-00.gif"
TYPE RASTER
OFFSITE 0 0 0
STATUS ON
CLASS
NAME 'Current RADAR'
# TEMPLATE "radar.html"
END
END # LAYER
# Layer for County Boundaries
LAYER
SIZEUNITS pixels
PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
"init=epsg:32039"
END
NAME border
TYPE POLYGON
DATA /var/www/mesonet/texas/data/counties.shp
STATUS DEFAULT
LABELITEM "name"
CLASSITEM "name"
# LABELMAXSCALE 2000000
# LABELMINSCALE 50000
LABELMAXSCALE 1000
CLASS
#NAME 'County Boundaries'
EXPRESSION /./
OUTLINECOLOR 181 181 145
LABEL
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS FALSE
BUFFER -5
END
END
END
#Airport Layer
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME airports
TYPE POINT
# DATA txairports_dd # old data file
DATA ARPT
STATUS OFF
CLASS
NAME 'Airports'
COLOR 128 255 164
SYMBOL 'circle'
SIZE 7
TEMPLATE "airports.html"
END
HEADER "airports_header.html"
FOOTER "airports_footer.html"
END
# Start of Weather layers definitions
# Metar Points (Query-able)
# <!-- Color, size changed 2003 03 23 gc -->
# <!-- This way, if there's no wind, and the site's clear, it looks like it -->
LAYER
SIZEUNITS pixels
#SIZEUNITS kilometers
PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
"init=epsg:32039"
END
NAME weather-metar
# STATUS DEFAULT
# STATUS off ###Changed 2003-07-13
TYPE POINT
DATA currentWeather
STATUS ON
LABELCACHE OFF
# TOLERANCE 3
TOLERANCE 15 #Changed 2003-07-13 gc
CLASS
NAME 'Weather Sites'
# COLOR 100 200 164
COLOR 0 0 0
SYMBOL 'circle'
# SIZE 7
SIZE 8
TEMPLATE "weather_refresh.html"
END
END
# PWV values
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
# "init=epsg:32039"
#END
CLASSITEM "pwv"
NAME weather-pwv
TYPE POINT
DATA currentWeather
#DATA currentPWV
STATUS ON
LABELCACHE ON
LABELITEM "pwv"
CLASS
EXPRESSION ([pwv] >= 0.0 AND [pwv] <= 0.05)
NAME 'PWV 0.00-0.05 in'
COLOR 224 224 224
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 4
# BUFFER -10 #-15
BUFFER 15 ### Changed 2003-07-13
PARTIALS TRUE
END
END
CLASS
NAME '0.05-0.20 in'
EXPRESSION ([pwv] > 0.05 and [pwv] <= 0.20)
COLOR 117 117 0
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
# BUFFER -10
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '0.20-0.40 in'
EXPRESSION ([pwv] > 0.20 and [pwv] <= 0.40)
COLOR 255 0 0
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '0.40-0.60 in'
EXPRESSION ([pwv] > 0.40 and [pwv] <= 0.60)
COLOR 255 145 46
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '0.60-0.80 in'
EXPRESSION ([pwv] > 0.600 and [pwv] <= 0.80)
COLOR 255 237 26
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '0.80-1.00 in'
EXPRESSION ([pwv] > 0.80 and [pwv] <= 1.00)
COLOR 166 255 18
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '1.00-1.20 in'
EXPRESSION ([pwv] > 1.00 and [pwv] <= 1.20)
COLOR 102 255 0
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '1.20-1.40 in'
EXPRESSION ([pwv] > 1.20 and [pwv] <= 1.400)
COLOR 15 255 128
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '1.40-1.60 in'
EXPRESSION ([pwv] > 1.400 and [pwv] <= 1.600)
COLOR 18 224 255
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '1.80-1.60 in'
EXPRESSION ([pwv] > 1.60 and [pwv] <= 1.800)
COLOR 18 191 255
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '1.80-2.00 in'
EXPRESSION ([pwv] > 1.800 and [pwv] <= 2.00)
COLOR 8 89 255
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
CLASS
NAME '>2.00 in'
EXPRESSION ([pwv] > 2.00)
COLOR 0 0 255
SYMBOL 'pwvcircle'
SIZE 15
LABEL
FORCE TRUE
COLOR 140 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UC
OFFSET 2 6
BUFFER 15
PARTIALS TRUE
END
END
END
# Wind Barbs
LAYER
#SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME weather-barbs
TYPE POINT
DATA currentWeather
STATUS ON
LABELITEM "WINDCHR"
LABELANGLEITEM "MAPWINDDIR"
LABELCACHE ON
CLASS
LABEL
FORCE TRUE
COLOR 0 0 0
# SHADOWCOLOR 128 128 128
# SHADOWSIZE 0 0
TYPE truetype
FONT ESRI_weather
SIZE 40
# SIZE 30
POSITION UR
OFFSET -4 -5 # for size 30 UR
# BUFFER 10
BUFFER -15
PARTIALS TRUE
END
END
END
# Metar Site Labels
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME weather-mlabel
TYPE POINT
DATA currentWeather
STATUS OFF
LABELITEM "ABBR"
CLASS
LABEL
FORCE TRUE
COLOR 180 180 180
TYPE BITMAP
SIZE SMALL
POSITION CR
OFFSET 7 0
BUFFER 15 ### changed 2003-07-13, old value == -5
PARTIALS TRUE
END
END
END
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME weather-mrain
TYPE POINT
DATA currentWeather
STATUS ON
LABELITEM "precip"
CLASS
LABEL
FORCE TRUE
COLOR 20 50 250
TYPE BITMAP
SIZE MEDIUM
POSITION LR
OFFSET 2 2
BUFFER 15
PARTIALS TRUE
END
END
END
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME weather-vis
TYPE POINT
DATA currentWeather
STATUS ON
LABELITEM "vis"
CLASS
LABEL
FORCE TRUE
COLOR 200 50 50
TYPE BITMAP
SIZE SMALL
POSITION CL
OFFSET 3 0
BUFFER 5
PARTIALS TRUE
END
END
END
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME weather-mdew
TYPE POINT
DATA currentWeather
STATUS ON
LABELITEM "dewp"
CLASS
LABEL
FORCE TRUE
COLOR 0 160 0
TYPE BITMAP
SIZE MEDIUM
POSITION LL
OFFSET 2 4
# BUFFER -5
BUFFER 5 #-10
PARTIALS TRUE
END
END
END
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME weather-mslp
TYPE POINT
DATA currentWeather
STATUS ON
LABELITEM "slp"
TOLERANCE -1000 ### changed 2003-07-13
CLASS
LABEL
FORCE TRUE
COLOR 0 0 160
TYPE BITMAP
SIZE MEDIUM
POSITION UR
OFFSET 4 7
BUFFER 5
PARTIALS TRUE
END
END
END
LAYER
SIZEUNITS pixels
#PROJECTION
# "proj=lcc"
# "ellps=GRS80"
# "lon_0=100w"
# "lat_1=27.416n"
# "lat_2=34.916n"
#END
NAME weather-mtemp
TYPE POINT
DATA currentWeather
STATUS ON
LABELITEM "temp"
CLASS
LABEL
FORCE TRUE
COLOR 255 0 0
TYPE BITMAP
SIZE MEDIUM
POSITION UL
OFFSET 2 4
BUFFER 5
PARTIALS TRUE
END
END
END
LAYER
#SIZEUNITS pixels
NAME credits
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS 4 696 END
TEXT ' '
END
CLASS
LABEL
TYPE TRUETYPE
FONT ESRI_weather
SIZE 50
ANTIALIAS true
COLOR 0 0 0
POSITION UR
END
END
END
# Use a layer like this for db data
# http://postgis.refractions.net/pipermail/postgis-users/2001-August/000192.html
LAYER
SIZEUNITS pixels
CONNECTIONTYPE postgis
NAME "temp"
# Connect to a remote spatial database
CONNECTION "user=postgres password=mesonet dbname=metar host=mesodata.cs.tamu.edu"
# Get the lines from the 'geom' column of the 'roads' table
DATA "temp from datatest join tblsites ON site=siteabbr"
STATUS OFF
TYPE POINT
# Of the lines in the extents, only render the wide highways
# FILTER "type = 'highway' and numlanes >= 4"
CLASS
# Make the superhighways brighter and 2 pixels wide
#EXPRESSION ([numlanes] >= 6)
COLOR 255 22 22
SYMBOL "circle"
SIZE 2
END
END
END # Map File
--------------060506070601010802090905--
