[Mapserver-users] problem with WMS Client support
Swaminathan, Gayathri
gayathri at ou.edu
Mon Jun 2 09:40:00 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C3290C.76DCBCF0
Content-Type: text/plain;
charset="utf-8"
Content-Transfer-Encoding: quoted-printable
Hi:
Got the same error messages when I was trying to compile through a "CL"
too....If you changed u_short to short the ushort errors will go...
You will still have this following error.,
=20
../libwww/library/src\HTHstMan.h(94) : error C2079: 'sock_addr' =
verwendet
undefiniertes struct 'sockaddr_in'
=20
The sockaddr_in is defined in the wwwsys.h which in turn refers in.h =
which
is in the cygwin
=20
All the problems however vanish if Mapserver is compiled in a VC++
environment...with supporting libs mentioned in the lib directories and
supporting libraries mentioned in the include....
=20
Please check out the conversation Rosangela Silva and me have been =
having
on this....
=20
But really dont know why the libwww...does not work well with the "CL"
compiler.
HTH,
Gayathri
-----Original Message-----
Sent: Monday, June 02, 2003 1:40 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] problem with WMS Client support
I=E2=80=99am trying to compile the UMN Mapserver with the WMS Client =
support and
always get the following error-message:
=20
=20
WIN32 /c mapwms.c /Fomapwms.obj
mapwms.c
mapwms.c(44) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(44) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
formalen und uebergebenen Parameter 1
mapwms.c(46) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(46) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(170) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(170) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(589) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(589) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(745) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(745) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(828) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(828) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(832) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(832) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(836) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(836) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(859) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(859) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(879) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(879) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(906) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(906) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(918) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(918) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(983) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(983) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(1053) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(1053) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(1387) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(1387) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(1388) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(1388) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(1400) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(1400) : warning C4024: 'strncasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(1401) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(1401) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(1403) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwms.c(1403) : warning C4024: 'strcasecmp' : Unterschiedliche Typen =
fuer
mapwms.c(1424) : warning C4013: 'getpid' undefiniert; Annahme: extern =
mit
Rueckgabetyp int
cl /nologo /Zi /W3 /DDEBUG /DWIN32 -I../gd-1.8.4
-I../tiff-v3.5.5/libtiff -I../proj-4.4.3/src -I..\php-4.0.4\regex
-DPHP_NO_ALIASES -I..\gdal-1.1.8/ogr/ogrsf_frmts -I..\gdal-1.1.8/ogr
-I..\gdal-1.1.8/ogr/../port -I..\gdal-1.1.8/core =
-I../libwww/library/src
-I../libwww/modules/expat/xmlp
arse -I ../arcsde/include -DNEED_STRCASECMP -DNEED_STRNCASECMP =
-DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_TIFF -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_WBMP -DUSE_GD_TTF -DUSE_GD_TTF -DGD_HAS_GDIMAGEGIFPTR =
-DUSE_OGR
-DUSE_WMS -DUSE_WMS_LYR -DIGNORE_MISSING_DATA -DFEATURE_INFO_HTML
-DUSE_SDE -D
WIN32 /c mapwmslayer.c /Fomapwmslayer.obj
mapwmslayer.c
../libwww/library/src\HTProt.h(58) : error C2061: Syntaxfehler : =
Bezeichner
'HTProtocolId'
../libwww/library/src\HTProt.h(58) : error C2059: Syntaxfehler : ';'
../libwww/library/src\HTProt.h(85) : error C2146: Syntaxfehler : =
Fehlendes
')' vor Bezeichner 'port'
../libwww/library/src\HTProt.h(85) : error C2081: 'HTProtocolId' : =
Name in
der formalen Parameterliste ist ungueltig
../libwww/library/src\HTProt.h(85) : error C2061: Syntaxfehler : =
Bezeichner
'port'
../libwww/library/src\HTProt.h(85) : error C2059: Syntaxfehler : ';'
../libwww/library/src\HTProt.h(85) : error C2059: Syntaxfehler : ','
../libwww/library/src\HTProt.h(88) : error C2059: Syntaxfehler : ')'
../libwww/library/src\HTProt.h(132) : error C2061: Syntaxfehler : =
Bezeichner
'HTProtocol_id'
../libwww/library/src\HTProt.h(132) : error C2059: Syntaxfehler : ';'
../libwww/library/src\HTProt.h(132) : error C2059: Syntaxfehler : =
'type'
../libwww/library/src\HTHost.h(65) : error C2146: Syntaxfehler : =
Fehlendes
')' vor Bezeichner 'u_port'
../libwww/library/src\HTHost.h(65) : error C2081: 'u_short' : Name in =
der
../libwww/library/src\HTHost.h(65) : error C2061: Syntaxfehler : =
Bezeichner
'u_port'
../libwww/library/src\HTHost.h(65) : error C2059: Syntaxfehler : ';'
../libwww/library/src\HTHost.h(65) : error C2059: Syntaxfehler : ')'
../libwww/library/src\HTHost.h(66) : error C2146: Syntaxfehler : =
Fehlendes
../libwww/library/src\HTHost.h(66) : error C2081: 'u_short' : Name in =
der
../libwww/library/src\HTHost.h(66) : error C2061: Syntaxfehler : =
Bezeichner
'u_port'
../libwww/library/src\HTHost.h(66) : error C2059: Syntaxfehler : ';'
../libwww/library/src\HTHost.h(66) : error C2059: Syntaxfehler : ')'
../libwww/library/src\HTHstMan.h(60) : error C2061: Syntaxfehler :
Bezeichner 'u_short'
verwendet
../libwww/library/src\HTHstMan.h(110) : error C2059: Syntaxfehler : =
mapwmslayer.c(292) : warning C4013: 'index' undefiniert; Annahme: =
extern mit
Rueckgabetyp int
mapwmslayer.c(292) : warning C4047: '=3D' : Anzahl der =
Dereferenzierungen bei
'const char *' und 'int ' unterschiedlich
mapwmslayer.c(340) : warning C4013: 'isspace' undefiniert; Annahme: =
extern
mit Rueckgabetyp int
mapwmslayer.c(368) : warning C4090: 'function' : Unterschiedliche
'const'-Bezeichner
mapwmslayer.c(368) : warning C4024: 'strcasecmp' : Unterschiedliche =
Typen
fuer formalen und uebergebenen Parameter 2
NMAKE : fatal error U1077: 'cl' : Rueckgabe-Code '0x2'
Stop.
=20
=20
=20
Does anyone have an idea of what is going wrong?
=20
Thanks,
Witte
Content-Type: text/html;
charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:o =3D=20
"urn:schemas-microsoft-com:office:office" xmlns:w =3D=20
"urn:schemas-microsoft-com:office:word"><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dutf-8">
<META content=3DWord.Document name=3DProgId>
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<META content=3D"Microsoft Word 10" name=3DOriginator><LINK=20
href=3D"cid:filelist.xml at 01C328F3.4A274F40" rel=3DFile-List><!--[if gte =
mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<STYLE>@page Section1 {size: 595.3pt 841.9pt; margin: 70.85pt 70.85pt =
2.0cm 70.85pt; mso-header-margin: 35.4pt; mso-footer-margin: 35.4pt; =
mso-paper-source: 0; }
P.MsoNormal {
FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; =
mso-style-parent: ""; mso-pagination: widow-orphan; =
mso-fareast-font-family: "Times New Roman"
LI.MsoNormal {
DIV.MsoNormal {
A:link {
COLOR: blue; TEXT-DECORATION: underline; text-underline: single
SPAN.MsoHyperlink {
A:visited {
COLOR: purple; TEXT-DECORATION: underline; text-underline: single
SPAN.MsoHyperlinkFollowed {
SPAN.EmailFormatvorlage17 {
COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: =
personal-compose; mso-style-noshow: yes; mso-ansi-font-size: 10.0pt; =
mso-bidi-font-size: 10.0pt; mso-ascii-font-family: Arial; =
mso-hansi-font-family: Arial; mso-bidi-font-family: Arial
DIV.Section1 {
page: Section1
</STYLE>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Normale Tabelle";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
</style>
<![endif]--></HEAD>
<BODY lang=3DDE style=3D"tab-interval: 35.4pt" vLink=3Dpurple =
link=3Dblue>
<DIV><SPAN class=3D343153415-02062003><FONT face=3DArial =
color=3D#0000ff=20
size=3D2>Hi:</FONT></SPAN></DIV>
color=3D#0000ff size=3D2>Got=20
the same error messages when I was trying to compile through a "CL" =
too....If=20
you changed u_short to short the ushort errors will =
go...</FONT></SPAN></DIV>
color=3D#0000ff size=3D2>You=20
will still have this following error.,</FONT></SPAN></DIV>
size=3D2> </DIV>
<P class=3DMsoNormal><FONT face=3DArial color=3D#0000ff size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: =
Arial">../libwww/library/src\HTHstMan.h(94)=20
: error C2079: 'sock_addr' verwendet undefiniertes struct=20
'sockaddr_in'</SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"></SPAN></FONT> </P>
<P class=3DMsoNormal><FONT color=3D#0000ff><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"><o:p><SPAN=20
class=3D343153415-02062003>The sockaddr_in is defined in the wwwsys.h =
which in=20
turn refers in.h which is in the cygwin</SPAN></o:p></SPAN></FONT></P>
class=3D343153415-02062003></SPAN></o:p></SPAN></FONT> </P>
class=3D343153415-02062003>All the problems however<STRONG> =
vanish</STRONG> if=20
Mapserver is compiled in a VC++ environment...with supporting libs =
mentioned in=20
the lib directories and supporting libraries mentioned in the=20
include....</SPAN></o:p></SPAN></FONT></P>
class=3D343153415-02062003>Please check out the conversation Rosangela =
Silva =20
and me have been having on this....</SPAN></o:p></SPAN></FONT></P>
class=3D343153415-02062003>But really dont know why the =
libwww...does not=20
work well with the "CL" compiler.</SPAN></o:p></SPAN></FONT></P>
class=3D343153415-02062003>HTH,</SPAN></o:p></SPAN></FONT></P>
class=3D343153415-02062003>Gayathri</SPAN></o:p></SPAN></FONT></P></FONT=
></SPAN>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
size=3D2>-----Original Message-----<BR><B>From:</B> J=C3=B6rn Witte=20
[mailto:jwitte at gmx.at]<BR><B>Sent:</B> Monday, June 02, 2003 1:40=20
AM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> =
[Mapserver-users] problem with WMS Client =
support<BR><BR></FONT></DIV>
<DIV class=3DSection1>
<P class=3DMsoNormal><FONT face=3DArial size=3D2><SPAN lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: =
EN-GB">Hi,<o:p></o:p></SPAN></FONT></P>
EN-GB">I=E2=80=99am=20
trying to compile the UMN Mapserver with the WMS Client support and =
always get=20
the following error-message:<o:p></o:p></SPAN></FONT></P>
EN-GB"><o:p> </o:p></SPAN></FONT></P>
EN-GB">WIN32 /c=20
mapwms.c /Fomapwms.obj<o:p></o:p></SPAN></FONT></P>
<P class=3DMsoNormal><FONT face=3DArial size=3D2><SPAN=20
Arial">mapwms.c<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(44) : warning =
C4090:=20
'function' : Unterschiedliche =
'const'-Bezeichner<o:p></o:p></SPAN></FONT></P>
C4024:=20
'strcasecmp' : Unterschiedliche Typen fuer formalen und uebergebenen =
Parameter=20
1<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(46) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(170) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(589) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(745) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(828) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(832) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(836) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(859) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(879) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(906) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(918) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(983) : warning =
C4090:=20
C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(1053) : =
warning C4090:=20
warning C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(1387) : =
warning C4090:=20
warning C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(1388) : =
warning C4090:=20
warning C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(1400) : =
warning C4090:=20
warning C4024:=20
'strncasecmp' : Unterschiedliche Typen fuer formalen und uebergebenen =
Parameter 1<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(1401) : =
warning C4090:=20
warning C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(1403) : =
warning C4090:=20
warning C4024:=20
Parameter=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwms.c(1424) : =
warning C4013:=20
'getpid' undefiniert; Annahme: extern mit Rueckgabetyp=20
int<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"><SPAN=20
style=3D"mso-spacerun: =
yes"> </SPAN>cl=20
/nologo /Zi /W3 /DDEBUG /DWIN32 -I../gd-1.8.4 =
-I../tiff-v3.5.5/libtiff<SPAN=20
style=3D"mso-spacerun: yes"> =
</SPAN>-I../proj-4.4.3/src<SPAN=20
style=3D"mso-spacerun: yes"> </SPAN>-I..\php-4.0.4\regex=20
-DPHP_NO_ALIASES -I..\gdal-1.1.8/ogr/ogrsf_frmts -I..\gdal-1.1.8/ogr=20
-I..\gdal-1.1.8/ogr/../port -I..\gdal-1.1.8/core<SPAN=20
style=3D"mso-spacerun: yes"> </SPAN>-I../libwww/library/src=20
-I../libwww/modules/expat/xmlp<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">arse -I =
../arcsde/include<SPAN=20
style=3D"mso-spacerun: yes"> </SPAN>-DNEED_STRCASECMP=20
-DNEED_STRNCASECMP<SPAN style=3D"mso-spacerun: yes"> =20
</SPAN>-DUSE_PROJ -DUSE_PROJ_API_H -DUSE_TIFF<SPAN=20
style=3D"mso-spacerun: yes"> </SPAN>-DUSE_GD_GIF -DUSE_GD_PNG=20
-DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_TTF<SPAN style=3D"mso-spacerun: =
yes"> =20
</SPAN>-DUSE_GD_TTF -DGD_HAS_GDIMAGEGIFPTR -DUSE_OGR -DUSE_WMS=20
-DUSE_WMS_LYR<SPAN style=3D"mso-spacerun: yes"> =20
</SPAN>-DIGNORE_MISSING_DATA <SPAN=20
style=3D"mso-spacerun: yes"> </SPAN>-DFEATURE_INFO_HTML =
-DUSE_SDE=20
-D<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">WIN32 /c mapwmslayer.c=20
/Fomapwmslayer.obj<o:p></o:p></SPAN></FONT></P>
Arial">mapwmslayer.c<o:p></o:p></SPAN></FONT></P>
Arial">../libwww/library/src\HTProt.h(58)=20
: error C2061: Syntaxfehler : Bezeichner=20
'HTProtocolId'<o:p></o:p></SPAN></FONT></P>
: error C2059: Syntaxfehler : ';'<o:p></o:p></SPAN></FONT></P>
Arial">../libwww/library/src\HTProt.h(85)=20
: error C2146: Syntaxfehler : Fehlendes ')' vor Bezeichner=20
'port'<o:p></o:p></SPAN></FONT></P>
: error C2081: 'HTProtocolId' : Name in der formalen Parameterliste =
ist=20
ungueltig<o:p></o:p></SPAN></FONT></P>
: error C2061: Syntaxfehler : Bezeichner =
: error C2059: Syntaxfehler : ','<o:p></o:p></SPAN></FONT></P>
Arial">../libwww/library/src\HTProt.h(88)=20
: error C2059: Syntaxfehler : ')'<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">../libwww/library/src\HT=
Prot.h(132)=20
'HTProtocol_id'<o:p></o:p></SPAN></FONT></P>
Arial">../libwww/library/src\HTProt.h(132)=20
: error C2059: Syntaxfehler : 'type'<o:p></o:p></SPAN></FONT></P>
Arial">../libwww/library/src\HTHost.h(65)=20
'u_port'<o:p></o:p></SPAN></FONT></P>
: error C2081: 'u_short' : Name in der formalen Parameterliste ist=20
Arial">../libwww/library/src\HTHost.h(66)=20
Arial">../libwww/library/src\HTHstMan.h(60)=20
'u_short'<o:p></o:p></SPAN></FONT></P>
'sockaddr_in'<o:p></o:p></SPAN></FONT></P>
Arial">../libwww/library/src\HTHstMan.h(110)=20
: error C2059: Syntaxfehler : '}'<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwmslayer.c(292) : =
warning=20
C4013: 'index' undefiniert; Annahme: extern mit Rueckgabetyp=20
warning=20
C4047: '=3D' : Anzahl der Dereferenzierungen bei 'const char *' und =
'int '=20
unterschiedlich<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwmslayer.c(340) : =
warning=20
C4013: 'isspace' undefiniert; Annahme: extern mit Rueckgabetyp=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">mapwmslayer.c(368) : =
warning=20
C4090: 'function' : Unterschiedliche=20
warning=20
C4024: 'strcasecmp' : Unterschiedliche Typen fuer formalen und =
uebergebenen=20
Parameter 2<o:p></o:p></SPAN></FONT></P>
EN-GB">NMAKE :=20
fatal error U1077: 'cl' : Rueckgabe-Code =
'0x2'<o:p></o:p></SPAN></FONT></P>
EN-GB">Stop.<o:p></o:p></SPAN></FONT></P>
EN-GB">Does=20
anyone have an idea of what is going =
wrong?<o:p></o:p></SPAN></FONT></P>
EN-GB">Thanks,<o:p></o:p></SPAN></FONT></P>
EN-GB">Witte<o:p></o:p></SPAN></FONT></P></DIV></BLOCKQUOTE></BODY></HTM=
L>
------_=_NextPart_001_01C3290C.76DCBCF0--
