[Mapserver-users] strange behaviour of LABELANGLEITEM
Randy James
rjames57 at yahoo.com
Tue Jun 3 13:31:31 EDT 2003
Hi
If each letter is an seperate point than you get the
results you have. If you want to turn the whole string than
you should have the whole string as a label for a single
point.
Cheers
--- Lowell Filak <lfilak at medinaco.org> wrote:
> I believe it is most likely a GD/FreeType-mismatch issue.
> You should be able to find something on the resolution in
> the archives.
> HTH
> Lowell F.
> The following message was sent by
> =?iso-8859-15?q?Bj=F6rn=20Platzen?= <bplatzen at sosnetz.de>
> on Tue, 3 Jun 2003 15:57:39 +0200.
> > Hi List,
> > I have point-layers for the labeling of the streets,
> where the dbf-file
> > provides the information about the angle of the lable
> (in degrees).
> > It seems, as if every letter is turned instead of the
> whole label.
> > In my Mapfile it looks like this:
> > LAYER
> > NAME strassennamen1
> > TYPE annotation
> > STATUS on
> > MAXSCALE 7500
> > MINSCALE 3400
> > DATA NebenStrassennamen_text
> > LABELITEM "Strname"
> > LABELANGLEITEM "Text_angle"
> > CLASS
> > LABEL
> > ANTIALIAS true
> > PARTIALS FALSE
> > POSITION cc
> > TYPE TRUETYPE
> > SIZE 8
> > FONT swiss
> > COLOR 0 0 0
> > END #LABEL
> > END #CLASS
> > END #LAYER
> > The output can be found under
> http://www.ividata.de/map_aachen.gif
> > A Version with non-turned labels is under
> > http://www.ividata.de/map_aachen2.gif (just to see the
> labels text...)
> > The degree-information looks like
> > 35.000000
> > 297.000000
> > 18.000000
> > 309.000000
> > 58.000000
> > The shapes and dbf's were generated by MapInfo.
> > I hope, that anybody can tell me, what's wrong...
> > Bye,
> > Bjoern
> > small office solutions
> > info at sosnetz.de - http://www.sosnetz.de
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Do you Yahoo!?
Yahoo! Calendar - Free online calendar with sync to Outlook(TM).
http://calendar.yahoo.com
