[Mapserver-users] shp2img segfaults
Frank Warmerdam
warmerdam at pobox.com
Thu Jun 5 09:09:51 EDT 2003
Michael Schulz wrote:
> Hi there,
> the get-together-mails sound promising, i'd really have liked to come to
> the MUM, but not this year ...
> But the real problem is: I have a mapserver nightly build from end of
> may (tried also the recent nightly), php-mapscript and python-mapscript
> work fine only the mapserv executable and shp2img give me a segfault
> when trying to render a map-file with a tiff raster layer... When i
> comment out the raster layer everything works fine, python mapscript
> draws a nice picture with the raster only mapserv/shp2img don't. MS
> 3.6.3 draws the map-file without a problem.
> This is my config.status:
> ./configure --with-gd=static,/usr/local/gd-2.0.12gif/
> --with-freetype=/usr/local/src/freetype-2.1.0
> --with-tiff=/usr/local/src/tiff-v3.5.7
> --with-gdal=/usr/local/src/gdal-1.1.8/apps/gdal-config
> --with-ogr=/usr/local/src/gdal-1.1.8/ogr
> --with-proj=/usr/local/src/proj-4.4.5 --with-jpeg=/usr/local/src/jpeg-6b
> --with-png --with-wmsclient --with-php=/usr/local/src/php-4.3.1/
Michael,
I would suggest configuring --without-tiff to ensure the TIFF handling
goes through GDAL instead of the more direct MapServer libtiff support. If
you want the direct support, then please ensure your GDAL is built with
an external libtiff 3.5.7 as well. Note that this is fairly antique
and the builtin version of libtiff in GDAL is essentially 3.6.0 beta.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
