[Mapserver-users] itemquery / itemnquery
Robert Fritz
robert-fritz at web.de
Sat Jun 7 05:20:16 EDT 2003
Hello,
i use html-frames & javascript in every frame. on frame contains a form for
user-inputs which are used for itemquery, another frame keeps the map. it
works fine, the user can change the input-values and send new requests, the
result is shown in the map-frame.
but if i change the mode to itemnquery, things are getting strange:
i can send only on request and then i get javascript-errors form the
map-frame if i try to send a new request.
the javascript errors tell me, that some of my hidden-parameters (e.g.
document.mapform.imgxy) are not available, but they are there.
i do not understand what happens, because the only thing i change is the
mode : from ITEMQUERY to ITEMNQUERY.
Where do I have to look for the source of error - my JavaScripts, my
Request-Url, my MapFile?
Is there a difference between itemquery - itemnquery? Do I have to set more
parameters using ITEMNQUERY?
--- Map File Excerpt
LAYER
NAME fsquery
TYPE POLYGON
STATUS ON
DATA flurstuecke
Filter ("[flaechennu]" =~ /%wert%/) # I change my Filter via URL
CLASS
Name "gesuchtes Flurstück"
Symbol "diagonalfill"
Size 8
END
TEMPLATE map.html # keeps my Map-Frame
END
Thank you,
robert
