[Mapserver-users] Problem with inline features/persistence
from a URL....?
Steve Lime
steve.lime at dnr.state.mn.us
Mon Jun 9 12:15:01 EDT 2003
If you're really only using a single feature then try setting ??? to
[map_extras_feature_points]. Remember, anything passed in can be gotten
out. If you have multiple features then it's a bigger deal and you'd
probably need to use a bit of javascript and a submit form handler to
make it work.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> AMC Story <s9646183 at sms.ed.ac.uk> 06/09/03 10:06AM >>>
Hi everyone,
I've recently been experimenting with inline features as a way to draw
additional point symbols on my maps. What I would like to do is to
have a text-
based front page, where users can click on a hyperlink and be taken to
a map
showing the feature and the area around it. As the locations of these
features
will change dynamically, I want to be able to write a script that
provides the
initial URL's for all the links based on the current data. What I
really want
to avoid is hardcoding these new features each in their own version of
the
template file.
An example URL would be:
<p align="left">The <a
href="http://tsunami.geo.ed.ac.uk/local-bin/mapserver?
map=%2Fusr%2Flocal%2Fapache%2Flocal-bin%2Fs9646183%2Finterface%
2Fdemo_interactive.map&layer=labels&zoomsize=2&imgext=-4.000000+55.000000+-
2.000000+57.000000&map_extras_feature=new&map_extras_feature_points=-
3.000000+56.000000&program=%2Flocal-bin%2Fmapserver&map_web_imagepath=%2Fusr%
2Flocal%2Fapache%2Fhtdocs%2Ftmp%2F&map_web_imageurl=%2Ftmp%2F">Map</a></p>
However, the problem here is that as soon as the user interacts with
the map
(i.e. zooms in or out), the template file is called and this seems to
delete
the inline features specified in the original url. Is there anyway to
make
this part of the url persistent? For example, can a variable be set in
the
template file that is then somehow obtained from the original url?
Eg: in the template file:
<input type="hidden" name="map_extras_feature" value="new">
<input type="hidden" name="map_extras_feature_points" value="???">
Sorry if this is a daft question, but any suggestions would be
gratefully
received.
Many thanks again for your help. Your previous suggestions have been
real life-
savers :)
Ali
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
