[Mapserver-users] Problems with in multi-layer maps (postGIS or mapServer?) - find_srid
Ignacio Laplagne
laplagnegeo at softhome.net
Wed Jun 11 17:46:40 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_002B_01C33049.DF9CFFE0
Content-Type: text/plain;
charset="US-ASCII"
Content-Transfer-Encoding: 7bit
We are working with mapServer+postGIS and are having a problem which we
believe is due to a bug (we cannot make sure whether this is due to
postGIS or mapServer; it could be even due to postgreSQL?): when working
with multi-layer map files with "complex" data and filter sections, the
resulting queries sent to PostgreSQL seem to be definitely wrong.
Consider the map file attached, and the first two layers. The DATA
section in layer "deptos" (supposedly the first to be drawn) causes the
following query being sent to postgreSQL:
DECLARE mycursor BINARY CURSOR FOR SELECT
porc::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::tex
t from ( select gid as oid, deptos.the_geom, p.prov as prov, p.porc as
porc, p.id_a as id_a, p.ed as ed from paisdeptos97 deptos join
calc__porc_x_ed_x_indra_x_alianza_c p on deptos.indra=cast(p.indra as
character varying)) as foo WHERE (foo.ed=112 AND foo.id_a=1 AND (0=1 OR
foo.prov='04')) and (the_geom && setSRID( 'BOX3D(3233646.7768
6112213.86,4187074.2232
6748025.14)'::BOX3D,find_srid('','paisdeptos97','the_geom') ))
Everything is just fine with this (believe me!). However, the second
layer causes the following query to be sent to postgres:
t from ( select gid as oid, c.the_geom, p.prov as prov, p.porc as porc,
p.id_a as id_a, p.ed as ed from circuito c join
calc__porc_x_ed_x_indrac_x_alianza_c p on c.indra=cast(p.indra as
6112213.86,4187074.2232 6748025.14)':
:BOX3D,find_srid('','circuitoos97','the_geom') ))
The big problem with this new query is the call to find_srid (in the
last line):
Now, the name "circuitoos97" doesn't correspond to any table mentioned
in the data section of the file, or any table in the database. Indeed,
this name would correspond to writing the word "circuito" OVER THE SAME
MEMORY POSITION than the word "paisdeptos97", which is exactly the name
used in the first call to the function find_srid (you can see it on the
query generated to draw the first layer). This suggests that somewhere
there is some piece of code missing for erasing the contents of that
memory position, or setting the right limit for these strings, etc.
Any suggestion or patch for this? We are currently working with the
following environment:
Redhat linux 8.0
postgreSQL 7.3.2
postgis 0.7.5
mapServer 3.6.5
Thanks in advance,
Ignacio Laplagne
Content-Type: application/octet-stream;
name="mpac.map"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="mpac.map"
# mpa =3D mapa de alianzas
name mapin
EXTENT 2952219 3899185 4740795 7592801
size 900 600
symbolset "/var/www/html/ews/v1.0/symbols/symbols35.sym"
web
template tM1j.html
imagepath "/var/www/html/tmp/"
imageurl "/tmp/"
end
querymap
size 200 150
status on
style hilite
color 255 128 0
end
scalebar
imagecolor 255 255 255
label
color 0 0 0
size tiny
end
style 1
size 72 3
color 0 0 0
units kilometers
intervals 2
transparent true
status embed
position lr
end
legend
status on
label
type bitmap
size medium
color 0 0 0
end
end
reference
status on
image "/var/www/html/ews/v1.0/images/pais.png"
size 150 108
extent 2952219 3899185 4740795 7592801
color -1 -1 -1
outlinecolor 255 0 0
end
# layer definitions ---------------------------------------------
LAYER
CONNECTIONTYPE postgis
NAME "deptos"
CONNECTION "user=3Dpostgres dbname=3Dgisdb"
data "the_geom from ( select gid as oid, deptos.the_geom, p.prov as =
prov, p.porc as porc, p.id_a as id_a, p.ed as ed from paisdeptos97 =
deptos join calc__porc_x_ed_x_indra_x_alianza_c p on =
deptos.indra=3Dcast(p.indra as character varying)) as foo"
filter "foo.ed=3D%MPed% AND foo.id_a=3D%MPpp% AND (%MPsap%=3D1 OR =
foo.prov=3D'%MPprov%')"
STATUS DEFAULT
TYPE POLYGON
CLASS EXPRESSION ([porc] > 0.60) COLOR 0 0 0 OUTLINECOLOR 0 0 =
0 END
CLASS EXPRESSION ([porc] > 0.45) COLOR 107 0 0 OUTLINECOLOR 107 0 =
0 END
CLASS EXPRESSION ([porc] > 0.40) COLOR 157 0 0 OUTLINECOLOR 157 0 =
0 END
CLASS EXPRESSION ([porc] > 0.35) COLOR 223 0 0 OUTLINECOLOR 223 0 =
0 END
CLASS EXPRESSION ([porc] > 0.30) COLOR 254 0 0 OUTLINECOLOR 254 0 =
0 END
CLASS EXPRESSION ([porc] > 0.27) COLOR 209 93 0 OUTLINECOLOR 209 93 =
0 END
CLASS EXPRESSION ([porc] > 0.24) COLOR 233 105 0 OUTLINECOLOR 233 =
105 0 END
CLASS EXPRESSION ([porc] > 0.21) COLOR 254 114 0 OUTLINECOLOR 254 =
114 0 END
CLASS EXPRESSION ([porc] > 0.18) COLOR 254 135 40 OUTLINECOLOR 254 =
135 40 END
CLASS EXPRESSION ([porc] > 0.15) COLOR 254 154 74 OUTLINECOLOR 254 =
154 74 END
CLASS EXPRESSION ([porc] > 0.12) COLOR 254 172 105 OUTLINECOLOR 254 =
172 105 END
CLASS EXPRESSION ([porc] > 0.09) COLOR 254 188 135 OUTLINECOLOR 254 =
188 135 END
CLASS EXPRESSION ([porc] > 0.06) COLOR 254 204 165 OUTLINECOLOR 254 =
204 165 END
CLASS EXPRESSION ([porc] > 0.03) COLOR 254 221 195 OUTLINECOLOR 254 =
221 195 END
CLASS EXPRESSION ([porc] > 0.02) COLOR 254 237 225 OUTLINECOLOR 254 =
237 225 END
CLASS EXPRESSION ([porc] > 0.01) COLOR 254 249 225 OUTLINECOLOR 254 =
249 225 END
CLASS EXPRESSION ([porc] > 0.008) COLOR 139 139 139 OUTLINECOLOR 139 =
139 139 END
CLASS EXPRESSION ([porc] > 0.006) COLOR 180 180 180 OUTLINECOLOR 180 =
180 180 END
CLASS EXPRESSION ([porc] > 0.004) COLOR 219 219 219 OUTLINECOLOR 219 =
219 219 END
CLASS EXPRESSION ([porc] > 0.000001) COLOR 250 250 250 OUTLINECOLOR 250 =
250 250 END
CLASS EXPRESSION ([porc] < 0.000001) COLOR 255 255 255 OUTLINECOLOR 255 =
255 255 END
END
LAYER
NAME "circuitos"
TRANSPARENCY 90
data "the_geom from ( select gid as oid, c.the_geom, p.prov as =
prov, p.porc as porc, p.id_a as id_a, p.ed as ed from circuito c join =
calc__porc_x_ed_x_indrac_x_alianza_c p on c.indra=3Dcast(p.indra as =
filter "foo.ed=3D%MPed% AND foo.id_a=3D%MPpp% AND (%MPsap%=3D1 =
OR foo.prov=3D'%MPprov%')"
STATUS DEFAULT
TYPE POLYGON
CLASS EXPRESSION ([porc] > 0.60) COLOR 0 0 0 =
OUTLINECOLOR 0 0 0 END
CLASS EXPRESSION ([porc] > 0.45) COLOR 107 0 0 =
OUTLINECOLOR 107 0 0 END
CLASS EXPRESSION ([porc] > 0.40) COLOR 157 0 0 =
OUTLINECOLOR 157 0 0 END
CLASS EXPRESSION ([porc] > 0.35) COLOR 223 0 0 =
OUTLINECOLOR 223 0 0 END
CLASS EXPRESSION ([porc] > 0.30) COLOR 254 0 0 =
OUTLINECOLOR 254 0 0 END
CLASS EXPRESSION ([porc] > 0.27) COLOR 209 93 0 =
OUTLINECOLOR 209 93 0 END
CLASS EXPRESSION ([porc] > 0.24) COLOR 233 105 0 =
OUTLINECOLOR 233 105 0 END
CLASS EXPRESSION ([porc] > 0.21) COLOR 254 114 0 =
OUTLINECOLOR 254 114 0 END
CLASS EXPRESSION ([porc] > 0.18) COLOR 254 135 40 =
OUTLINECOLOR 254 135 40 END
CLASS EXPRESSION ([porc] > 0.15) COLOR 254 154 74 =
OUTLINECOLOR 254 154 74 END
CLASS EXPRESSION ([porc] > 0.12) COLOR 254 172 105 =
OUTLINECOLOR 254 172 105 END
CLASS EXPRESSION ([porc] > 0.09) COLOR 254 188 135 =
OUTLINECOLOR 254 188 135 END
CLASS EXPRESSION ([porc] > 0.06) COLOR 254 204 165 =
OUTLINECOLOR 254 204 165 END
CLASS EXPRESSION ([porc] > 0.03) COLOR 254 221 195 =
OUTLINECOLOR 254 221 195 END
CLASS EXPRESSION ([porc] > 0.02) COLOR 254 237 225 =
OUTLINECOLOR 254 237 225 END
CLASS EXPRESSION ([porc] > 0.01) COLOR 254 249 225 =
OUTLINECOLOR 254 249 225 END
CLASS EXPRESSION ([porc] > 0.008) COLOR 139 139 139 =
OUTLINECOLOR 139 139 139 END
CLASS EXPRESSION ([porc] > 0.006) COLOR 180 180 180 =
OUTLINECOLOR 180 180 180 END
CLASS EXPRESSION ([porc] > 0.004) COLOR 219 219 219 =
OUTLINECOLOR 219 219 219 END
CLASS EXPRESSION ([porc] > 0.000001) COLOR 250 250 250 =
OUTLINECOLOR 250 250 250 END
CLASS EXPRESSION ([porc] < 0.000001) COLOR 255 255 255 =
OUTLINECOLOR 255 255 255 END
STATUS DEFAULT
TYPE POLYGON
END
LAYER
NAME "deptos_vacios"
data "the_geom from paisdeptos97"
CLASS SYMBOL 'circle' SIZE 1 OUTLINECOLOR 0 0 0 END
STATUS DEFAULT
TYPE POLYGON
END
LAYER
NAME "provincias"
data "the_geom from provincias"
CLASS SYMBOL 'circle' SIZE 2 OUTLINECOLOR 0 0 0 END
STATUS DEFAULT
TYPE POLYGON
END
# end of layer defs -------------------------------
END # end of map file
------=_NextPart_000_002B_01C33049.DF9CFFE0--
