[Mapserver-users] proj.pm build problem
    Dana Quinn
    dana at nextbus.com
    Wed Jun 11 18:05:12 PDT 2003
Hi, I found the fix to this problem, I should have posted it
back to the list.  I do it now so hopefully it will link
up in the list archives.
Again, Perl 5.8, RH 8.0 (and a pretty uptodate RH 8.0 at that -
newest kernel and so on).  I found what I needed in the
Mapserver wiki - Perl MapScript, then Perl 5.8 -
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptPerl5.8
this specifically relates to the perl mapscript build, but I
had the same sort of lines in the proj_wrap.c file for
proj.pm.  Here's what the wiki page for mapscript said:
Contributed by Joe Bussell
     The interface code in mapscript_wrap.c is broken for PERL 5.8.
     Specifically, the macro XS(boot_mapscript) must be declared if the
PERL object is not declared.
     In my world line 431 which reads:
     SWIGEXPORT(void) boot_mapscript(CV* cv);
     should be replaced with:
     XS(boot_mapscript);
Thanks to Joe for posting that, whenever he did.
I changed the proj_wrap.c in an analogous fashion, and my build
went to completion!  Things work fine now.
Dana
Steve Lime wrote:
> It's probably an issue with Swig and perl 5.8. I remember seeingthe
> issue
> come up on the SWIG mailing list. Using the latest version of Swig
> (from
> www.swig.org) may help. You can install that code and rebuild the
> module
> by running 'swig -perl5 -shadow proj.i' and building as normal. I'll be
> looking
> into it on this end cause we're upgrading all of our RedHat machines
> but
> that may not happen for a couple of weeks.
> Steve
>>>>Dana Quinn <dana at nextbus.com> 06/05/03 11:51AM >>>
> This is a little bit obscure, but I'll give it a
> try.  I'm trying to build the proj.pm that Steve
> Lime released a while back, and I getting a strange
> message that's keeping it from building.  I
> haven't seen this before, and thought I'd ask about
> it here.
> (I'm building on a RH 8.0/Perl 5.8 system)
> so after I do 'perl Makefile.PL', I do a make and get
> this:
> $ make
> cp proj.pm blib/lib/proj.pm
> gcc -c  -I/u1/src/ms/proj/include -D_REENTRANT -D_GNU_SOURCE
> -fno-strict-aliasing -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
> -I/usr/include/gdbm -O2 -march=i386 -mcpu=i686   -DVERSION=\"\"
> -DXS_VERSION=\"\" -fpic
> "-I/usr/lib/perl5/5.8.0/i386-linux-thread-multi/CORE"   proj_wrap.c
> proj_wrap.c: In function `_swig_create_magic':
> proj_wrap.c:416: warning: assignment from incompatible pointer type
> proj_wrap.c:417: warning: assignment from incompatible pointer type
> proj_wrap.c: At top level:
> proj_wrap.c:750: conflicting types for `boot_proj'
> proj_wrap.c:431: previous declaration of `boot_proj'
> make: *** [proj_wrap.o] Error 1
> Does anyone have any ideas what could be going on here?  My
> normal troubleshooting technique (pasting the error message into
> google), didn't return any matches (sort of amazing).  I must
> be doing something wrong.  I am running a different version
> of glibc than another RH8.0 system that this worked on - is
> it possible that it could cause a problem?
> Any help would be appreciated!
> Dana
> PS I also re-swig'd, which didn't help, and kind of made things
> worse actually.
> PPS Wish I could be with you all there at the users conference!
> Have fun!
Dana Quinn, dana at nextbus.com
NextBus Information Systems
(510) 420-3117
More information about the MapServer-users
