[Mapserver-users] Mapserver WMS as server to ArcIMS service
Paul Ramsey
pramsey at refractions.net
Thu Jun 12 16:35:44 EDT 2003
Is this correct? I was of the understanding that the ArcIMS WMS
connector exposes the ArcIMS data as a WMS server. So if you have set up
the WMS connector on ArcIMS you can use a WMS client to view the ArcIMS
data. In fact, I have seen it in action in the government here, and have
cascaded a mapserver service onto an ArcIMS server which used the WMS
connector.
It is the opposite direction, the ArcIMS server *pulling* data from a
WMS server, which I whink it impossible... yes?
P.
Ed McNierney wrote:
> Drew -
> The ArcIMS "OGC Connector" allows an ArcIMS server to connect to WMS
> layers served by OGC-compliant servers. It's a one-way pipe (we call it
> the "OGC Diode") because it does NOT permit WMS clients to read data
> from ArcIMS servers. But it sounds like this is something your ArcIMS
> partners should already be able to do.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> *From:* Simpson, Andrew [mailto:Andrew.Simpson at ssc.nasa.gov]
> *Sent:* Thursday, June 12, 2003 3:18 PM
> *To:* 'mapserver-users at lists.gis.umn.edu'
> *Subject:* [Mapserver-users] Mapserver WMS as server to ArcIMS service
> Good Afternoon,
> Has anyone had any success using Mapserver WMS as a source for an
> ArcIMS service? Would like to share some raster data with an
> offsite group that only speaks ArcIMS.
> Used the IMS Emulator to connect with ArcMap and ArcCatalog
> (http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0110/msg00298.html),
> which worked very well.
> Sorry for the slightly off topic question.
> Thanks for any info,
> Drew.
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
