[Mapserver-users] Querybypoint succes GetNumResult 1 shapeindex -1 Why?
jose.quintal at cfe.gob.mx
Thu Jun 12 19:21:37 EDT 2003
Of a data base of Mysql I take hold points with its coordinates x and y
them drawing and all OK, But when doing a Querybypoint shapeindex returns
to me -1 That I have bad?
Here I keep the points in a ShapeObj object
//Conectando con Mysql
mysql_pconnect("dwa00","sist","sist") or die("No abrio el servidor");
mysql_select_db("mapas") or die("No selecciono la Base de Datos");
//Seleccionando Postes
$sql="SELECT * from postes_Mer WHERE identificador = '$buscar' ";
$p=mysql_query($sql) or die("Error al Ejecutar la Consulta");
//Arma la consulta
// get a layer object representing your pointlayer
$layerObj = $map->getLayerByName("postes");
// get a class object representing the first class in the layer
$classObj = $layerObj->getClass(0);
// create a new point object to hold the X Y data
$pointObj = ms_newPointObj();
$line = ms_newLineObj();
$i=0;
while($reg=mysql_fetch_array($p))
$a=$reg['num_campo'];
$b=$reg['cor_x'];
$c=$reg['cor_y'];
$pointObj->setXY($b,$c);
$line ->add($pointObj);
$shp = ms_newShapeObj(MS_SHAPE_POINT);
$shp->add($line);
$shp->{text} = $a;
$shp->{index} = $i;
if($layerObj->addFeature($shp) == -1){
echo "addFeature failed";
$point_lookup[$i] = $a;
$i++;
$pointObj->draw($map, $layerObj, $image, 0, $a);
Here this the code where I make the Querybypoint
if ($info_pt == 1 )
$record = -1;
$layerObj = $map->getLayerByName('postes');
$queryresult = @$map->queryByPoint ($ptClicked,MS_SINGLE,1000);
echo "Queryresult " . $queryresult;
if ($queryresult == SUCCES)
$results = $layerObj->resultcache;
$layerObj->open($results);
$num_results = $layerObj->getNumResults();
echo "Num resultados :" . $num_results;
// we only expect one result.
$rslt[0] = $layerObj->getResult(0);
// this is an index into the point lookup table.
$shapeindex[0]=$rslt[0]->shapeindex;
$tileindex[0]=$rslt[0]->tileindex;
echo "rsultado : " . $rslt[0];
echo "tile : " . $tileindex[0];
echo "shape :" . $shapeindex[0];
Here this the definition of the Layer in the .map where I make the
Querybypoint
LAYER
NAME "postes"
TYPE POINT
STATUS ON
TOLERANCE 10
LABELMINSCALE 10
LABELMAXSCALE 60000
TEMPLATE "postes.html"
CLASS
SYMBOL 'circle'
COLOR 0 0 0
SIZE 5
MINSIZE 5
MAXSIZE 5
LABEL
ANTIALIAS TRUE
TYPE TRUETYPE
FONT Arialn
SIZE 8
POSITION CL
BUFFER 2
MINDISTANCE -3
MINFEATURESIZE -1
COLOR 252 152 54
PARTIALS TRUE
FORCE FALSE
END
END
END
Thanks
José Antonio Quintal Castillo
Sistemas
Comision Federal de Electricidad
Tel 9243128 O 9243136
