[Mapserver-users] On-The-Fly Projection
Shaik A. Hussain
shussain at atsincorp.com
Fri Jun 13 14:03:25 EDT 2003
Greetings,
I am having problem with On-The-Fly-Projection. I am using mapserver 3.6.4, windows 2000, apache.
My out put image projection is in Pennsylvania Polyconic, other layers with different projection spaces, one in PA Albert Conic, Geographic and PA State Plan South NAD27.
The layer which has PA State plan south nad27 is not showing , other layers are showing correctly. Does any one help me what is wrong with the Projection definition for the PA State plan.
Here is my map projection definitions.
Out put image projection definition at map level is PENNSYLVANIA POLYCONIC.
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
#"units=m"
END
Layer Level Projection Definition is PENNSYLVANIA STATE PLAN SOUTH NAD 27.
LAYER
NAME "Landuse"
STATUS Default
DATA "landuse"
TYPE POLYGON
CLASS
NAME "Landuse"
COLOR 0 255 0
OUTLINECOLOR 255 0 0
SYMBOL 'circle'
SIZE 2
END
PROJECTION
"proj=lcc"
"ellps=clrk66"
"lat_1=39.933333333n"
"lat_2=40.800000000n"
"lat_0=39.333333333n"
"lon_0=77.750000000w"
"x_0=609601.219"
"y_0=0.000"
# "to_meter=0.3048006096"
"datum=NAD27"
"no_defs"
END
END
Thanks,
Anwar
www.atsincorp.com
