[Mapserver-users] Flash Capabilities
woodbri at swoodbridge.com
Sun Jun 15 10:39:43 EDT 2003
OK, where are the keepers of the flash secrets? I did what seemed to
be the obvious thing to do and get a swf file and load it, but I
don't see a map. So I must be missing the secret hand-shake or
something :) Here is the php script I created which seems to work
just fine, except the map does not show in the browser:
<HTML>
<BODY BGCOLOR="#CCCCCC">
<CENTER>
<H1>PHP/MapScript module test</H1>
<?php
dl("php_mapscript.so");
$map = ms_newMapObj("demo.map");
$map->selectOutputFormat("SWF");
$img = $map->draw();
$url = $img->saveWebImage();
<OBJECT classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swfl
ash.cab#version=6,0,0,0"
WIDTH="<?php echo $map->width; ?>" HEIGHT="<?php echo $map->height;
?>" id="map" ALIGN="">
<PARM NAME=movie VALUE="><?php echo $url; ?>">
<PARM NAME=quality VALUE=high>
<PARM NAME=bgcolor VALUE=#CCCCCC>
<EMBED src="<?php echo $url; ?>" quality=high bgcolor=#CCCCCC
?>" NAME="map" ALIGN="" TYPE="application/x-shockwave-flash"
PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer"></EMBED>
</OBJECT>
</BODY>
</HTML>
The OUTPUTFORMAT block in the mapfile looks like:
OUTPUTFORMAT
NAME swf
DRIVER "SWF"
MIMETYPE "application/x-shockwave-flash"
EXTENSION "swf"
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=SINGLE"
# FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
and doing the same thing with a PNG image works fine.
Any help here would be appreciated.
-Steve W.
On 13 Jun 2003 at 12:40, woodbri at swoodbridge.com wrote:
> Hi Flashy People,
> I read this over and plan to give it a try:
> http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html
> Is this document current or has more been done on this?
> Do you have a priority wishlist?
> Who is the principal developer on this?
> I wanted to animate a route, like have each successive segment
> highlight after a short delay and then repeat. Is this possible? How
> hard would it be to implement? I saw some comments in the doc above
> about highlighing, but it seemed to imply that this was not done yet.
> I would probably have the route in its own layer if that makes a
> difference.
> I think some people have posted links to their apps, but if anyone can
> share what they have done, I would be willing to add it to the Wiki
> page and add my experiences to it.
> Thanks,
> -Steve W.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
