[Mapserver-users] Serving PostGIS Projected Data
Benjamin Wragg
bwragg at tpg.com.au
Mon Jun 16 17:57:42 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_000F_01C334A1.F1E79190
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi list,
With my limited use of PostGIS and MapServer I've only ever played
around with data in geographic coordinates which is loaded into PostGIS
with an SRID of -1. I now need to load up some data that is in a custom
Mercator projection (changed the central meridian to 150 instead of 0).
The SRID number of our custom projection in the spatial_ref_sys table is
999001 which is based on the record with an SRID of 54004. The proj4text
for 999001 looks like "+proj=merc +lat_ts=0 +lon_0=150 +k=1.000000
+x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 units=m". When I load up the
data, each record has an SRID of 999001.
Is this all I need to do on the PostGIS side of things?
I've now added the layer to a bare mapfile but the data is showing up
like it would with a -1 srid. I have no projection information of any
sort defined in the mapfile so I assume I need to define a PROJECTION
section in the mapfile. Correct?
How do I do this for a custom projection? I've found examples on the
list like the following which show how to enter the projection section
in a mapfile, but I can't figure out what I should put in here.
PROJECTION
"proj=lcc"
"ellps=GRS80"
"lat_0=49"
"lon_0=-95"
"lat_1=49"
"lat_2=77"
END
Thanks,
Benjamin Wragg
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html>
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
pre
{margin:0cm;
font-size:10.0pt;
font-family:"Courier New";}
span.emailstyle17
{font-family:Arial;
color:windowtext;}
span.EmailStyle19
{font-family:Arial;
color:navy;}
@page Section1
{size:595.3pt 841.9pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-AU link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi list,</span></font></p>
font-family:Arial'> </span></font></p>
font-family:Arial'>With my limited use of PostGIS and MapServer =
I’ve only
ever played around with data in geographic coordinates which is loaded =
into
PostGIS with an SRID of -1. I now need to load up some data that is in a =
custom
Mercator projection (changed the central meridian to 150 instead of 0). =
The
SRID number of our custom projection in the spatial_ref_sys table is =
999001
which is based on the record with an SRID of 54004. The proj4text for =
999001
looks like “+proj=3Dmerc +lat_ts=3D0 +lon_0=3D150 +k=3D1.000000 =
+x_0=3D0 +y_0=3D0
+ellps=3DWGS84 +datum=3DWGS84 units=3Dm”. When I load up the data, =
each record
has an SRID of 999001.</span></font></p>
font-family:Arial'>Is this all I need to do on the PostGIS side of =
things?</span></font></p>
font-family:Arial'>I’ve now added the layer to a bare mapfile but =
the
data is showing up like it would with a -1 srid. I have no projection
information of any sort defined in the mapfile so I assume I need to =
define a
PROJECTION section in the mapfile. Correct?</span></font></p>
font-family:Arial'>How do I do this for a custom projection? I’ve =
found
examples on the list like the following which show how to enter the =
projection
section in a mapfile, but I can’t figure out what I should put in =
here.</span></font></p>
<pre><font size=3D2 face=3D"Courier New"><span =
style=3D'font-size:10.0pt'>PROJECTION</span></font></pre><pre><font
size=3D2 face=3D"Courier New"><span style=3D'font-size:10.0pt'> =
"proj=3Dlcc"</span></font></pre><pre><font
"ellps=3DGRS80"</span></font></pre><pre><font
"lat_0=3D49"</span></font></pre><pre><font
"lon_0=3D-95"</span></font></pre><pre><font
"lat_1=3D49"</span></font></pre><pre><font
"lat_2=3D77"</span></font></pre><pre><font
style=3D'font-size:10.0pt'>END</span></font></pre><pre><font
style=3D'font-size:10.0pt'> </span></font></pre>
font-family:Arial'>Thanks,</span></font></p>
font-family:Arial'>Benjamin Wragg</span></font></p>
</div>
</body>
</html>
------=_NextPart_000_000F_01C334A1.F1E79190--
