[Mapserver-users] TIFF-Display
Vincent Schut
schut at sarvision.com
Tue Jun 17 09:08:26 EDT 2003
<snap>
Is there an image conversion
> tool to produce TIFFs that mapserver can show?
I use Imagemagick's tools quite regular; never encountered problems using
these images with mapserver. Usually, I convert images with it to 8 bit, add
a .tfw file and use gdal_translate to add a coordinate system, if needed.
Works as a charm.
Btw, you can use gdalinfo (I suppose you have compiled gdal?) to get
information about your tiff, e.g. if it is really still an 8-bit 256 colors
image...
Cheers,
Vincent.
> Thanks
> Olaf
> ----- Original Message -----
> From: Ed McNierney
> To: Olaf Knopp ; MapServer Liste
> Sent: Tuesday, June 17, 2003 2:35 PM
> Subject: RE: [Mapserver-users] TIFF-Display
> Olaf -
> How did you add geographic reference information to your TIFF so
> MapServer knows where it is in the world? You need to have created either
> a GeoTIFF with the coordinate info in the TIFF itself, or a world file with
> a TFW or WLD extension to go with it.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: (978) 251-4242 Fax: (978) 251-1396
> ed at topozone.com
> -----Original Message-----
> From: Olaf Knopp [mailto:oknopp at kartago.de]
> Sent: Tuesday, June 17, 2003 5:31 AM
> To: MapServer Liste
> Subject: [Mapserver-users] TIFF-Display
> Hello,
> i have got a problem with the display of a tiff-image. Mapserver shows a
> white map (and produces a white .png), but navigation is possible, the
> square on the refenenz map is ok and scale/scalebar also. There is no
> difference if the tiff is black/white (1 bit) or 8 bit, it never shows an i
> get no error message from mapserver.
> When i use another tiff from another project it works!!
> The tiff was made with IrfanView (no compression, 256 Colors (counted
> 16), 8 Bit):
> Here a part of my mapfile:
> LAYER
> NAME "Hintergrund"
> DATA "Stadtplan.tif"
> TYPE RASTER
> OFFSITE 1
> STATUS ON
> END
> Thanks for your help!
> Olaf
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
