[Mapserver-users] ASP and MapServer
    Lowell Filak
    lfilak at medinaco.org
    Tue Jun 17 06:52:49 PDT 2003
Unfortunately the index field must be in the dbf/database to provide a
link to the shape.
You could always take the original dbf and create a new dbf from it
which contains the index field or if your loading the data from the dbf
into something else you could populate the field as it is loaded.
Lowell
The following message was sent by "Mario" <noti at ciaoweb.it> on Tue, 17
Jun 2003 15:05:10 +0200.
> Hi Steve,
> dbase tables don't have indexed fields and when I query the database,
> I extract some records in a new recordset. If, as record number, you
> consider the absolute position in the original table I cannot have that
> number.
> Maybe it's possible to scroll all the database with a Find command but
> probably it would be very slow for large tables....
> I 'm new in mapserver, can I find somewhere sample code that opens >
shapefile
> and reads extents for a feature?
> Thank you
> Mario
> ----- Original Message -----
> From: <woodbri at swoodbridge.com>
> To: <mapserver-users at lists.gis.umn.edu>; "Mario" <noti at ciaoweb.it>
> Sent: Tuesday, June 17, 2003 2:02 PM
> Subject: Re: [Mapserver-users] ASP and MapServer
> > Hi Mario,
> > If you can read the dbf and have the record number, then you need to
> > open the shapefile and read the extents for that record number, then
> > you can call $map->setextent(xmin, ymin, xmax,ymax) and you should be
> > all set.
> > -Steve W.
> > On 17 Jun 2003 at 13:16, Mario wrote:
> > > Hi,
> > > I developed an ASP application that allow users to query dbase files
> > > in Shapefiles datasets. I'd like to pass records found to
MapServer > in
> > > order to zoom to their extents. How can I pass these records to
> > > MapServer?
> > > Any help appreciated
> > > Thanks
> > > Mario
More information about the MapServer-users
