[Mapserver-users] Flash Capabilities
Yewondwossen Assefa
assefa at dmsolutions.ca
Tue Jun 17 13:30:35 EDT 2003
--------------060508020406030806010703
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I could add something like SWFACTIONSCRIPT metadata (on the web object)
which can be use at save time to add specific actions script codes to
the main movie : In your case It would be:
Web
metadata
"SWFACTIONSCRIPT" "#inclue ./action/map.as;stop"
end
Would this be enough ?
Later,
Liangxu Wang wrote:
>Hi all,
> I am trying mapserver with swf output format now. There are some trouble with learning flash's action script when I planning use swf format.
> When I load a map swf file from my main flash file,I can't do some change with the map swf file. so,if the map file generate
>in the mapserver can dynamically load some specail action script from web server? for example, if exist "./action/map.as",the map swf file load it,just like this:
> stop;
> Sorry for my poor english.
>wlx
>----- Original Message -----
>From: "Yewondwossen Assefa" <assefa at dmsolutions.ca>
>To: <woodbri at swoodbridge.com>
>Cc: <mapserver-users at lists.gis.umn.edu>
>Sent: Tuesday, June 17, 2003 12:41 AM
>Subject: Re: [Mapserver-users] Flash Capabilities
>>Hi There,
>> Sorry for the late answer. I was out of the office since Friday.
>>woodbri at swoodbridge.com wrote:
>>>Hi Flashy People,
>>>I read this over and plan to give it a try:
>>>http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html
>> Most of the information is uptodate. Parts that needed updating :
>> - Events and Highlights : the document described the initial
>>proposition. It did not describe how It was currently implemented. I
>>have updated that part of the document to describe what currently exists.
>>>Is this document current or has more been done on this?
>>>Do you have a priority wishlist?
>>>Who is the principal developer on this?
>> There is no real priority list right now. I guess It will depend on how
>>things go when people use theis output more frequently.
>> I would be the main developper of this although I have had contribution
>>and suggestion from other developpers like Jan Hartmann.
>>>I wanted to animate a route, like have each successive segment
>>>highlight after a short delay and then repeat. Is this possible? How
>>>hard would it be to implement? I saw some comments in the doc above
>>>about highlighing, but it seemed to imply that this was not done yet.
>>>I would probably have the route in its own layer if that makes a
>>>difference.
>> Hightlighting is implemented as noted above. Right now a second shape
>>with the highlight color is drawn on top of the original shape when a
>>mouse over happens on the shape.
>> I am not sure how your case would be solved though. One possiblity
>>would be to export for each element, it x,y coordinates (same way as the
>>attributes are exported), and these coordinates would be accessible
>>through Action Script. This idea was intially proposed for symbol layers
>>to export the posisition of the symbols(x,y) and at the application
>>level, position flash symbols at these specific positions. If there
>>are other ideas, I would like to hear them.
>>>I think some people have posted links to their apps, but if anyone
>>>can share what they have done, I would be willing to add it to the
>>>Wiki page and add my experiences to it.
>>Later,
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body>
I could add something like SWFACTIONSCRIPT metadata (on the web object) which
can be use at save time to add specific actions script codes to the main
movie : In your case It would be:<br>
<br>
Web<br>
...<br>
metadata<br>
"SWFACTIONSCRIPT" "#inclue ./action/map.as;stop"<br>
...<br>
end<br>
<br>
Would this be enough ?<br>
<br>
Later,<br>
<br>
<br>
<br>
Liangxu Wang wrote:<br>
<blockquote type="cite" cite="mid00c901c33474$e299b240$f84dfea9 at gisedu">
<pre wrap="">Hi all,
stop;
wlx
From: "Yewondwossen Assefa" <a class="moz-txt-link-rfc2396E" href="mailto:assefa at dmsolutions.ca"><assefa at dmsolutions.ca></a>
To: <a class="moz-txt-link-rfc2396E" href="mailto:woodbri at swoodbridge.com"><woodbri at swoodbridge.com></a>
Cc: <a class="moz-txt-link-rfc2396E" href="mailto:mapserver-users at lists.gis.umn.edu"><mapserver-users at lists.gis.umn.edu></a>
</pre>
<blockquote type="cite">
<pre wrap="">Hi There,
<a class="moz-txt-link-abbreviated" href="mailto:woodbri at swoodbridge.com">woodbri at swoodbridge.com</a> wrote:
</pre>
<pre wrap="">Hi Flashy People,
<a class="moz-txt-link-freetext" href="http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html">http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html</a>
</pre>
</blockquote>
<pre wrap=""> Most of the information is uptodate. Parts that needed updating :
</pre>
<pre wrap="">Is this document current or has more been done on this?
</pre>
</blockquote>
<pre wrap=""> There is no real priority list right now. I guess It will depend on how
</pre>
<pre wrap="">I wanted to animate a route, like have each successive segment
difference.
</pre>
</blockquote>
<pre wrap=""> Hightlighting is implemented as noted above. Right now a second shape
</pre>
<pre wrap="">I think some people have posted links to their apps, but if anyone
</pre>
</blockquote>
<pre wrap="">Later,
Assefa Yewondwossen
Software Analyst
Email: <a class="moz-txt-link-abbreviated" href="mailto:assefa at dmsolutions.ca">assefa at dmsolutions.ca</a>
<a class="moz-txt-link-freetext" href="http://www.dmsolutions.ca/">http://www.dmsolutions.ca/</a>
Fax: (613) 565-0925
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
<pre class="moz-signature" cols="$mailwrapcol">--
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
</pre>
<br>
</body>
</html>
--------------060508020406030806010703--
