[Mapserver-users] RE: TIFF-Display
Andrés Collao
andres at mapserver.cl
Tue Jun 17 15:04:21 EDT 2003
I'm working with RASTER and the tif was made with ESRI - Arcview, then
rename the .TIFW file to .WLD. Uses Photoshop to convert the tif file to
GRAYSCALE
Mapserver 3.6.4 is not working with 24 or 16 bit files, only with 1bit.
>Hello,
>i have got a problem with the display of a tiff-image. Mapserver shows a
>white map (and produces a white .png), but navigation is possible, the
>square on the refenenz map is ok and scale/scalebar also. There is no
>difference if the tiff is black/white (1 bit) or 8 bit, it never shows an i
>get no error message from mapserver.
>When i use another tiff from another project it works!!
>The tiff was made with IrfanView (no compression, 256 Colors (counted 16),
>8 Bit):
>Here a part of my mapfile:
>LAYER
> NAME "Hintergrund"
> DATA "Stadtplan.tif"
> TYPE RASTER
> OFFSITE 1
> STATUS ON
>END
>Thanks for your help!
>Olaf
Atte.
Andrés Collao.
collao_andres at hotmail.com
"El hombre es un Dios cuando sueña y un mendigo cuando reflexiona".
:-- Il peggior nemico del succeso è la pauta del fallimiento
:-- El peor enemigo del éxito es el miedo al fracaso
_________________________________________________________________
Charla con tus amigos en línea mediante MSN Messenger:
http://messenger.yupimsn.com/
