[mapserver-users] 24 bit png, latlonbbox, pdf overlay
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jun 17 15:30:40 EDT 2003
Hi list,
I use mapserver 4.0 beta1 on ECW files. I use the WMS interface. I have
some questions about it:
ECW is ofcourse 24 bit, so it seems the most logical to me to request
mapserver for a 24 bit png image.
-when I request for an image of type png, I seem to get an 8 bit and not a
24 bit image. How do I get a 24 bit one? Will it be faster with 24 bit png
because no resampling has to be done? With jpeg it looks fine, with png the
colours seem to be different from the ECW source file, but that is probably
because of the resampling or not?
-in the capabilities the LatLonBoundingBox takes on the values from the SRS
in which the raster resides. Is it not better to provide dummy values in
the value range of latlon, or is it even possible to calculate them
(although then the caps will be slower).
-when I ask for an output of pdf an invalid pdf file is created. Should it
work?
-does mapserver also have the possibility to cascade with outputformat =
pdf, i.e. can it overlay pdf files coming from different servers (combine
into one pdf when I ask for layers=layer_1,layer_2&format=PDF where layer_1
and layer_2 coming from different servers)?
Thanks in advance for the answers,
Bart
