[Mapserver-users] Terra Server WMS
Ed McNierney
ed at topozone.com
Wed Jun 18 15:51:48 EDT 2003
Aaron -
Do you still get a blank map when you ask for an image near the center
of either zone? You'll still need to use the OFFSITE parameter
technique I mentioned earlier to get the zones to overlap properly.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242 Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
Sent: Wednesday, June 18, 2003 2:51 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Terra Server WMS
I have tried the group and extent and when I have more then one utm zone
in
the map file I get a blank map. My map file is below, is there something
I
am doing wrong.
# Start of map file
NAME test
STATUS ON
SIZE 500 500
EXTENT -77.89 40.77 -77.83 40.81
UNITS DD
SHAPEPATH "./"
IMAGECOLOR 235 235 235
INTERLACE ON
# Start of web interface definition
WEB
TEMPLATE demo.html
IMAGEPATH "/home/wcs/html/dy_images/"
IMAGEURL "/dy_images/"
END
PROJECTION
"proj=longlat"
"ellps=WGS84"
"unit=dd"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
LAYER
NAME "INC"
PROJECTION
"proj=longlat"
"ellps=WGS84"
"unit=dd"
END
STATUS OFF
DATA "/home/wcs/html/data/earth.tif"
TYPE RASTER
END
LAYER
NAME ortho-18
METADATA
"wms_title" "USGS Digital Ortho-Quadrangles"
"wms_srs" "EPSG:26918" #NAD83 UTM zone 18N
"wms_extent" "-78 0 -72 90"
LYRNAME "DOQs (orthophotos)"
LINK
"http://terraserver.microsoft.com/about.aspx?n=AboutTerraServiceOverview
END
GROUP "ORTHO DATA"
STATUS DEFAULT
TYPE RASTER
MINSCALE 1500
MAXSCALE 80000
CONNECTIONTYPE WMS
CONNECTION
"http://terraservice.net/ogcmap.ashx?VERSION=1.1.1&SERVICE=wms&LAYERS=DO
Q&FO
RMAT=png&styles="
PROJECTION
"init=epsg:26918" #NAD83 UTM zone 18N
END
END
LAYER
NAME ortho-17
METADATA
"wms_srs" "EPSG:26917" #NAD83 UTM zone 17N
"wms_extent" "-84 0 -78 90"
LINK
END
GROUP "ORTHO DATA"
STATUS DEFAULT
TYPE RASTER
MINSCALE 1500
MAXSCALE 80000
CONNECTIONTYPE WMS
CONNECTION
Q&FO
RMAT=png&styles="
PROJECTION
"init=epsg:26917" #NAD83 UTM zone 17N
END
END
END
----- Original Message -----
To: "Erich Schroeder" <erich at museum.state.il.us>
Cc: "Dylan Keon" <keon at nacse.org>; <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, June 17, 2003 12:20 PM
> Yep, declare them as separate layers with different zones, but give
them
> the same GROUP for handy toggling. Also make sure you include the
extent
> information in the wms metadata, so mapserver knows to ignore layers
> outside of its current view extent.
> P.
> Erich Schroeder wrote:
> > On Tue, 17 Jun 2003, Dylan Keon wrote:
> >> PROJECTION
> >> "init=epsg:26910" #NAD83 UTM zone 10N
> >> END
> > This is great! I'll be saving this message for future use!
> > In my case, I would be spanning two utm zones. How would I handle
this?
> > Should there be two doq layers, one for each zone, and then the html
form
> > turns both on when the user asks for DOQs?
> > Erich
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
