[Mapserver-users] Custom Projects
Daniel Morissette
morissette at dmsolutions.ca
Thu Jun 19 11:32:51 EDT 2003
Yes this should work.
> Benjamin Wragg wrote:
> Hi list,
> If I need to add a custom projection to mapserver I'm I correct in
> saying I can just define it correctly and add it to the bottom of say
> the /usr/local/share/proj/esri file, give it a unique number and then
> referance it in the mapfile as follows:
> PROJECTION
> "init=esri:CustomNumber"
> END
> where CustomNumber is the unique number choosen. Is there anything
> wrong with this?
> Thanks,
> Benjamin
