[Mapserver-users] CGI Error - ANY GUESSES?
Howard Mark
MHoward at spaceimaging.com
Thu Jun 19 14:21:07 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C3368F.5B59A732
Content-Type: text/plain; charset="iso-8859-1"
Brian,
YEP - right. I copied all the DLL's to the WINNT/system32 folder. Works now.
Even though the PATH was set to include the dll's - evidently the IIS user
does not use that path var.
THANKS!
Mark
-----Original Message-----
From: Brian Fischer [mailto:bfischer at houstonengineeringinc.com]
Sent: Thursday, June 19, 2003 11:57 AM
To: Howard Mark; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] CGI Error - ANY GUESSES?
I have seen this error when I forgot to copy some of the .dll files
mapserver requires into the system32 directory. Hope this helps.
Brian
From: Howard Mark [mailto:MHoward at spaceimaging.com]
Sent: Thursday, June 19, 2003 12:23 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] CGI Error - ANY GUESSES?
I feel really stupid about this. I have a perfectly good mapserver install
on a W2K machine. I'm putting together another demo on a laptop - same OS.
I copied everything I need to the new machine and have IIS running with the
same virtual directories and permissions.
I keep getting an error message running the app in a IE window.
CGI Error
The specified CGI application misbehaved by not returning a complete set of
HTTP headers. The headers it did return are:
If I run the request on the command line - I get an HTML document just fine
and the map image is created as well.
C:\>c:\Inetpub\Scripts\mapserv.exe
"QUERY_STRING=map=C:/inetpub/scripts/demosimple.map&layer=county"
Content-type: text/html
<!-- MapServer version 3.6.6-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 IN
PUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<html>
<head><title>MapServer Demo Interface</title></head>
<BODY BGCOLOR="#C4D1DD">
<img SRC="http:\\webgroup-lt\tmp\DEMO10560415982068.jpg" width=600
height=600 bo
rder=0>
</BODY>
</html>
ANY IDEAS ????
TIA
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
Content-Type: text/html; charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" xmlns:w=3D"urn:sc=
hemas-microsoft-com:office:word" xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; charset=3Diso-8859-=
1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 9">
<meta name=3DOriginator content=3D"Microsoft Word 9">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3365D.3EEC2E30">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:Zoom>0</w:Zoom>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:ForgetLastTabAlignment/>
<w:DoNotUseHTMLParagraphAutoSpacing/>
</w:Compatibility>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-pitch:variable;
mso-font-signature:553679495 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
p.MsoToc1, li.MsoToc1, div.MsoToc1
{margin-top:6.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:0in;
text-indent:.2in;
font-size:12.0pt;
font-weight:bold;
font-style:italic;}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:10.0pt;
span.emailstyle17
{mso-style-name:emailstyle17;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:black;}
span.emailstyle20
{mso-style-name:emailstyle20;
color:navy;}
span.EmailStyle21
{mso-style-type:personal-reply;
mso-ansi-font-size:10.0pt;
color:navy;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DEmailStyle21><font size=3D2 color=3Dnavy=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Brian,<o:p></o:p></span></font=
></span></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><![if !supportEmptyParas]>&nbs=
p;<![endif]><o:p></o:p></span></font></span></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>YEP – right. I copied al=
l the DLL’s
to the WINNT/system32 folder. Works now.<o:p></o:p></span></font></span></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Even though the PATH was set to
include the dll’s – evidently the IIS user does not use that pa=
th var.<o:p></o:p></span></font></span></p>
face=3DArial><span
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>THANKS!<o:p></o:p></span></fon=
t></span></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Mark<o:p></o:p></span></font><=
/span></p>
face=3DArial><span
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 color=3Dblack
face=3DTahoma><span style=3D'font-size:10.0pt;font-family:Tahoma;color:blac=
k'>-----Original
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b> Brian Fischer
[mailto:bfischer at houstonengineeringinc.com]<br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> Thursday, June 19, 2003
11:57 AM<br>
<b><span style=3D'font-weight:bold'>To:</span></b> Howard Mark;
mapserver-users at lists.gis.umn.edu<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> RE: [Mapserver-user=
s] CGI
Error - ANY GUESSES?</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 face=3D"Time=
s New Roman"><span
style=3D'font-size:10.0pt'><![if !supportEmptyParas]> <![endif]><o:p><=
/o:p></span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 color=3Dnavy=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>I have seen this er=
ror
when I forgot to copy some of the .dll files mapserver requires into the
system32 directory. Hope this helps.</span></font><font color=3Dblack=
><span
style=3D'color:black;mso-color-alt:windowtext'><o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;color:navy'> </span></font=
><font
color=3Dblack><span style=3D'color:black;mso-color-alt:windowtext'><o:p></o=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>Brian</span></font>=
<font
face=3DArial><span
><font
<p class=3DMsoNormal style=3D'margin-left:1.0in'><font size=3D2 color=3Dbla=
ck
k'>-----Original
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b> Howard Mark
[mailto:MHoward at spaceimaging.com] <br>
12:23 PM<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> [Mapserver-users] C=
GI
Error - ANY GUESSES?</span></font><font color=3Dblack><span style=3D'color:=
black;
ck
face=3D"Times New Roman"><span style=3D'font-size:10.0pt;color:black'> =
;</span></font><font
<p class=3DMsoNormal style=3D'margin-left:1.0in'><span class=3Demailstyle17=
><font
size=3D2 color=3Dblack face=3DArial><span style=3D'font-size:10.0pt;font-fa=
mily:Arial'>I
feel really stupid about this. I have a perfectly good mapserver install on=
a
W2K machine. I’m putting together another demo on a laptop – sa=
me OS.</span></font></span><font
><font
mily:Arial'>I
copied everything I need to the new machine and have IIS running with the s=
ame
virtual directories and permissions.</span></font></span><font color=3Dblac=
k><span
><font
mily:Arial'>I
keep getting an error message running the app in a IE window.</span></font>=
</span><font
><font
mily:Arial'> </span></font></span><font
><font
mily:Arial'><<<<<<<<<</span></font></span><font
><font
><font
mily:Arial'>CGI
Error</span></font></span><font color=3Dblack><span style=3D'color:black;
><font
mily:Arial'>The
specified CGI application misbehaved by not returning a complete set of HTTP
headers. The headers it did return are:</span></font></span><font color=3Db=
lack><span
><font
><font
mily:Arial'>>>>>>>>></span></font></span><font
><font
><font
mily:Arial'>If
I run the request on the command line – I get an HTML document just f=
ine and
the map image is created as well. </span></font></span><font color=3Dblack>=
<span
><font
><font
mily:Arial'>C:\>c:\Inetpub\Scripts\mapserv.exe
"QUERY_STRING=3Dmap=3DC:/inetpub/scripts/demosimple.map&layer=3Dco=
unty"</span></font></span><font
><font
><font
mily:Arial'>Content-type:
text/html</span></font></span><font color=3Dblack><span style=3D'color:blac=
k;
><font
mily:Arial'><!--
MapServer version 3.6.6-dev OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=
=3DWBMP
SUPPORTS=3DPROJ SUPPORTS=3DTTF SUPPORTS=3DWMS_SERVER SUPPORTS=3DWMS_CLIENT =
INPUT=3DEPPL7
IN</span></font></span><font color=3Dblack><span style=3D'color:black;mso-c=
olor-alt:
><font
mily:Arial'>PUT=3DOGR
INPUT=3DGDAL INPUT=3DSHAPEFILE --></span></font></span><font color=3Dbla=
ck><span
><font
mily:Arial'><html></span></font></span><font
><font
mily:Arial'><head><title>MapServer
Demo Interface</title></head></span></font></span><font
><font
mily:Arial'><BODY
BGCOLOR=3D"#C4D1DD"></span></font></span><font color=3Dblack><=
span
><font
mily:Arial'><img
SRC=3D"http:\\webgroup-lt\tmp\DEMO10560415982068.jpg" width=3D600
height=3D600 bo</span></font></span><font color=3Dblack><span style=3D'colo=
r:black;
><font
mily:Arial'>rder=3D0></span></font></span><font
><font
mily:Arial'></BODY></span></font></span><font
><font
mily:Arial'></html></span></font></span><font
><font
><font
mily:Arial'>ANY
IDEAS ????</span></font></span><font color=3Dblack><span style=3D'color:bla=
ck;
><font
><font
mily:Arial'>TIA
</span></font></span><font color=3Dblack><span style=3D'color:black;mso-col=
or-alt:
><font
><font
mily:Arial'>Mark</span></font></span><font
<p class=3DMsoNormal style=3D'margin-left:1.0in'><font size=3D3 color=3Dbla=
ck
face=3D"Times New Roman"><span style=3D'font-size:12.0pt;color:black'><br>
<br>
*****<br>
This message is intended only for the use of the Addressee and may<br>
contain information that is PRIVILEGED and CONFIDENTIAL.<br>
<br>
If you are not the intended recipient, you are hereby notified that any<br>
dissemination of this communication is strictly prohibited. If you have<br>
received this communication in error, please erase all copies of the<br>
message and its attachments and notify Space Imaging immediately.<br>
*****</span></font><font
</div>
<FONT SIZE=3D3><BR>
<BR>
*****<BR>
This message is intended only for the use of the Addressee and may<BR>
contain information that is PRIVILEGED and CONFIDENTIAL.<BR>
<BR>
If you are not the intended recipient, you are hereby notified that any<BR>
dissemination of this communication is strictly prohibited. If you have<BR>
received this communication in error, please erase all copies of the<BR>
message and its attachments and notify Space Imaging immediately.<BR>
*****<BR>
</FONT>
</body>
</html>
------_=_NextPart_001_01C3368F.5B59A732--
