[Mapserver-users] FLASH file action that generate by mapserver 4
Liangxu Wang
wlx at cngis.org
Fri Jun 20 01:20:32 EDT 2003
hi Yewondwossen Assefa,
I use Action scrpit viewer to explore the swf file that generate by mapserver 4.
The action is:
mapObj = new Object ();
mapObj.name = "test.map";
mapObj.width = 540;
mapObj.height = 470;
mapObj.numlayers = 3;
mapObj.layers = new Array ();
function LayerObj (name, type, fullname, relativename) {
this.name = name;
this.type = type;
this.fullname = fullname;
this.relativename = relativename;
mapObj.layers[0] = new LayerObj ("country.shp", "2", "d:/tmp/ms_tmp/105607646524641_layer_0.swf", "105607646524641_layer_0.swf");
mapObj.layers[1] = new LayerObj ("lakes.shp", "2", "d:/tmp/ms_tmp/105607646524641_layer_1.swf", "105607646524641_layer_1.swf");
mapObj.layers[2] = new LayerObj ("cities.shp", "0", "d:/tmp/ms_tmp/105607646524641_layer_2.swf", "105607646524641_layer_2.swf");
There is not a mapobj.extent attribute,this is not same with the flash document.(http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html)
Another suggestion :
The Layerobj's fullname attribute should web address,not local address.(like http://xxx/.../xxxxx.swf)
wlx
