[Mapserver-users] Deleting old GIF image files
Gregory S. Williamson
gsw at globexplorer.com
Mon Jun 23 04:04:27 EDT 2003
I found a utility that can do this for windows versions ... I don't see it in the downloads/utilities list currently. It was in a 50k file called "deltmpfiles.zip" ... I don't want to clutter mail unnecessarilty but if you can't find it I will send you my version.
Greg Williamson
DBA, GlobeXplorer LLC
This is what the "readme" file says:
deltmpfiles executable. Used to delete files older that a certain time.
Usage : deltmpfiles <directory> [hour]
<directory> : is the path to the directory where you want to delete files.
[hour] : optional. Delete files older than X hour (default value is 1 hour).
Example of Usage with NT scheduler :
1) Create a .bat file (ex : delfiles.bat) and add the following line
c:/deltmpfiles e:/tmp/ms_tmp
2) schedule the job using the At NT command :
at 03:00 /every:M,T,W,Th,F,S,Su "c:\delfiles.bat"
This will delete all files older the 1 hour in the directory e:/tmp/ms_tmp.
It will run every day at 3 am.
-----Original Message-----
Sent: Sun 6/22/2003 11:58 PM
To: mapserver-users at lists.gis.umn.edu
Cc:
Subject: [Mapserver-users] Deleting old GIF image files
Hi
I would like to know if anyone can suggest a sollution to my problem. I
have used MapServer to generate mapImages on the www.langelandatlas.dk
website. The problem is, that the ms_temp folder which contains the GIF
image files rapidly is filled with old image files which are no longer
used. Can MapServer be set ud to automatically delete the image files it
has created after they have been used?
Sincerely
Thomas Jensen
Sven Allan Jensen as
Sankelmarksgade 9
DK - 9000 Aalborg
Ph: 96 31 40 64
E-mail: tj at svaj.dk
www.svaj.dk
