Fw: [Mapserver-users] Deleting old GIF image files
Krzysztof Chodak
k.chodak at autoguard.pl
Mon Jun 23 04:49:55 EDT 2003
I personally use wsh script (Windows):
<job>
<script language="JSCript">
var fso = WScript.CreateObject("Scripting.FileSystemObject"),
startDate = new Date(),
folder = fso.GetFolder("D:\\tmp\\"),
files = new Enumerator(folder.Files),
file
while (!files.atEnd())
file = files.item()
if ((startDate - new Date(file.DateLastModified)) > 86400000)
file.Delete()
files.moveNext()
</script>
</job>
it is saved in CleanUpTemp.wsf file. I use Task Scheduling to run it from
time to time (currently once per day). Script is launched by following
command:
C:\WINNT\system32\cscript.exe CleanUpTemp.wsf
BR
Krzysztof Chodak
> ----- Original Message -----
> From: Thomas Jensen
> To: mapserver-users at lists.gis.umn.edu
> Sent: Monday, June 23, 2003 8:58 AM
> Subject: [Mapserver-users] Deleting old GIF image files
> Hi
> I would like to know if anyone can suggest a sollution to my problem. I
have
> used MapServer to generate mapImages on the www.langelandatlas.dk website.
> The problem is, that the ms_temp folder which contains the GIF image files
> rapidly is filled with old image files which are no longer used. Can
> MapServer be set ud to automatically delete the image files it has created
> after they have been used?
> Sincerely
> Thomas Jensen
> Sven Allan Jensen as
> Sankelmarksgade 9
> DK - 9000 Aalborg
> Ph: 96 31 40 64
> E-mail: tj at svaj.dk
> www.svaj.dk
