[Mapserver-users] Problem with tileindex. Was: Converting from png to geotiff with
gdal
David Monterroso Cabello
pyro-x at ixine.com
Mon Jun 23 13:03:14 EDT 2003
Hi all
Finally i managed to convert the raster files (in png) to
georefenced tiff files, i used the world files approach as Richard and
others pointed out, and now i have a collection of tiff files each one
with a .wld file.
After that if include one of these rectangles as an independent
raster layer in my mapserver project it just render fine, i can navigate
and do zooming all around that segment without problems.
But, if i include the tileindex generated with the gdal utility the
problems start, first the full map extent is rendered (that covers most
of the rectangles) and it draws fine, but when i zoom into it, then some
blank areas appears in the rendered image, if i keep zooming or paning
these blank areas make bigger or smaller, it seems like sometimes
mapserver can't get some of the rectangles, but they are there cause i
can see them if i pan or zoom out.
These is what i have in my map file:
# Just ONE rectangle
LAYER
NAME "test_trafico"
STATUS ON
DATA "mad_443440-4473776_444544-4474880.tiff"
TILEITEM "Location"
TYPE RASTER
END
# The whole tileindex
LAYER
NAME "tile_test"
STATUS ON
TILEINDEX "index.shp"
TILEITEM "Location"
TYPE RASTER
END
Have anyone experienced the same behaviour with tileindex?.
Many thanx in advance,
Richard Greenwood wrote:
> At 09:51 PM 6/9/2003 +0200, you wrote:
>> Hi all
>> I want to include into mapserver a new layer based on a
>> collection of raster files i have in PNG format, i know the extents
>> values for each image ( they are named as this:
>> mad_441600-4478928_442581-4479909.png ), it seems i need to convert
>> them to tiff (or geotiff?) format so i can include them in my project
>> and then make an index from them, but i can't just get along the
>> first step.
>> I've tried using gdal utilities to convert them from png to a tiff
>> with the geometry information using this:
>> gdalwarp -s_srs EPSG:23030 -t_srs EPSG:23030 -te 444544 4481872
>> 445525 4482853 mad_444544-4481872_445525-4482853.png test.tiff
>> But instead of a brand new tiff image this is what i get :
>> ERROR 1: Unable to compute a transformation between pixel/line
>> and georeferenced coordinates for mad_444544-4481872_445525-4482853.png.
>> There is no affine transformation and no GCPs.
> I would use gdal_translate rather than gdalwarp because you are not
> trying to change the projection, but that is not your problem.
> The coordinates of the image are in the file name, but no software
> that I am aware of is setup to read the coordinates in such a format.
> You need to convert the coordinates into a world file (*.wld or
> *.tfw). The world file is a separate, ASCII file having the same name
> (but .wld or .tfw extension) as the image file. It containing the
> coordinates of the upper left image pixel, the X and Y dimensions of
> each image pixel, and the rotation (must be 0,0).
> So for each image you need to create this world file, either by hand
> or by script.
> Rich
> Richard W. Greenwood, PLS
> Greenwood Mapping, Inc.
> Rich at GreenwoodMap.com
> (307) 733-0203
> http://www.GreenwoodMap.com
