AW: [Mapserver-users] WMS client problems
Arnulf Christl CCGIS
arnulf.christl at ccgis.de
Mon Jun 23 14:24:02 EDT 2003
I have loaded your project into our client and it returns an in-image
errormessage:
msProcessProjection(): no system list, errno:2??? (the rest it is not
readable).
Did you include the PROJ4 library?
You can check your MAP file with our client: http://wms.ccgis.de/ click on
"Country Boundaries". As long as you don't change any basic parameters in
your map file the client works as a WMS. If you add a layer, change the
projection or similar, then the project has to be reload.
If you want us to remove the link, just tell us.
Cheers, Arnulf.
-----Ursprungliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von USB
Gesendet: Donnerstag, 12. Juni 2003 10:11
An: 'mapserver-users at lists.gis.umn.edu'
Betreff: [Mapserver-users] WMS client problems
Hallo everyone,
I use Mapserver 3.6.6-gif-gdal with Apache 1.3.27 on WindowsXP. I tried to
connect several times MapServer to any WMS server with definition of layer
object -
LAYER
METADATA
"wms_title""Country Boundaries"
"wms_srs""EPSG:4269 EPSG:4326"
END
CONNECTIONTYPE WMS
CONNECTION
"http://TSADEV.SPECIESANALYST.NET/cgi-bin/mapserv.exe?map=cntryBound.map&VER
SION=1.0.0&LAYERS=country"
NAME 'wms'
TYPE raster
STATUS off
END # LAYER
but without any success. I obtained in html template only blank screen and
there are files *.img.tmp in image directory. If I use GetMap or
GetCapabilities in direct http request I will get image or xml doccument
without problems.
Then I could to establish my own WMS server and connect to it as WMS client.
But then I obtained - "msDrawRaster(): Image handling error. Unrecognized or
unsupported image format".
I am not sure what is wrong. Would you be so kind and could send me any
suggestions.
Best regards
J. Ruzicka
ruzicka at usbrno.cz
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
