Hello,
I have installed mapserver with gdlib, postgis and png support:
ldd ../../../cgi-bin/mapserv
libgd.so.2 => /usr/lib/libgd.so.2 (0x40025000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x4005c000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x4007d000)
libpng.so.3 => /usr/lib/libpng.so.3 (0x400cc000)
libz.so.1 => /lib/libz.so.1 (0x400f1000)
libpdf.so.1 => /usr/local/lib/libpdf.so.1 (0x400ff000)
libgdal.1.1.so => /usr/local/lib/libgdal.1.1.so (0x40193000)
libm.so.6 => /lib/i686/libm.so.6 (0x40408000)
libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x4042a000)
libc.so.6 => /lib/i686/libc.so.6 (0x404dd000)
libpq.so.3 => /usr/lib/libpq.so.3 (0x40610000)
libdl.so.2 => /lib/libdl.so.2 (0x40625000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40628000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
libssl.so.0.9.7 => /usr/lib/libssl.so.0.9.7 (0x40631000)
libcrypto.so.0.9.7 => /usr/lib/libcrypto.so.0.9.7 (0x4065f000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0x4074e000)
libresolv.so.2 => /lib/libresolv.so.2 (0x4077b000)
libnsl.so.1 => /lib/libnsl.so.1 (0x4078c000)
The creation of map from the database works very well, but when I try to
read a png file (with tfw file) the system crashes wit internal server
error. Does anybody have an idea of reasons for these results??
Does any incompatible versions of libraries between png and others exist?
Thanks a lot,
Carsten
