[Mapserver-users] mapserver crashes at a png file
Vincent Schut
schut at sarvision.com
Thu Jun 26 09:42:16 EDT 2003
Carsten,
I am afraid I don't know why your mapserver crashes on png's...
About the tiff issue: mapserver 3.6.x is not able to handle/output 24bit
color. So whatever image you deliver it, it should be indexed color (8bit).
If you want 24bit color you need to use mapserver-4.0 which is the cvs
(development) version now, but will be released quite soon afaik. I am using
this version all the time and it is pretty stable, so you could try if you
like. Btw if speed is an issue for you and harddisk space isn't, tiff as
input generally is faster that png because mapserver doesn't have to
uncompress it. At least, when you don't use tiff internal compression.
Regards,
Vincent.
On Thursday 26 June 2003 17:19, Carsten Busch wrote:
> Hello Vincent,
> Vincent Schut wrote:
> > Carsten,
> > sorry this is gonna be a very short answer cause I got to go home.
> > layers: see the mapserver cgi pages in the documentation on the website.
> > It will be somthing like 'layer=name&layer=name2&...' I think.
> > About the tiff thing: why would tiff work only with grayscale? Tiff's can
> > be rgb, anything you want.
> I did compile the mapserver with JPEG,PNG and TIFF support, but if I try
> to draw a colored tiff file I get the message:
> drawTIFF(): Image handling error. Only colormapped and grayscale raster
> are supported.
> So, I converted all the rgb tiff raster to indexed raster (only 256
> colors), after this the tiff rasters can be used as input data.
> -->rgb tiff does not work with mapserver (it is the same with jpeg)
> > About png not working: have you updated/recompiled something (notably a
> > library like gd, libpng or gdal) after compiling mapserver? Then you will
> > have to recompile mapserver.
> I did recompile one... n times the mapserver with the following options
> and results:
> mapserver-3.6.6]# ./configure --with-gd --with-gdal
> --with-zlib-dir=/usr/lib --with-regex=system --with-png-dir=/usr
> -with-postgis=/usr/local/pgsql/bin/pg_config --with-jpeg-dir=/usr
> --with-php=/usr/local/MapserverLinux/php-4.3.2
> loading cache ./config.cache
> checking for gcc... (cached) gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for c++... (cached) c++
> checking whether the C++ compiler (c++ ) works... yes
> checking whether the C++ compiler (c++ ) is a cross-compiler... no
> checking whether we are using GNU C++... (cached) yes
> checking whether c++ accepts -g... (cached) yes
> checking for ranlib... (cached) ranlib
> checking for flex... (cached) flex
> checking for yywrap in -lfl... (cached) yes
> checking for bison... (cached) bison -y
> checking if compiler supports -R... (cached) no
> checking if compiler supports -Wl,-rpath,... (cached) yes
> checking for exp in -lm... (cached) yes
> checking for exp in -lstdc++... (cached) yes
> checking how to run the C preprocessor... (cached) gcc -E
> checking for ANSI C header files... (cached) yes
> checking for strcasecmp... (cached) yes
> checking for strncasecmp... (cached) yes
> checking for strdup... (cached) yes
> checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
> using libjpeg from system libs.
> checking which version of GD to use...
> using libgd from system libs.
> checking where FreeType is installed...
> checking for FT_Init_FreeType in -lfreetype... yes
> using libfreetype -lfreetype from system libs.
> checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
> using libz from system libs.
> checking where PNG is installed...
> checking for png_init_io in -lpng... yes
> using libpng from system libs.
> checking for gdImageCreate in -lgd... yes
> checking for gdImageGif in -lgd... no
> checking for gdImagePng in -lgd... yes
> checking for gdImageJpeg in -lgd... yes
> checking for gdImageWBMP in -lgd... yes
> checking for gdImageStringFT in -lgd... yes
> checking for gdImageString16 in -lgd... yes
> checking for gdImageGifPtr in -lgd... no
> using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> -DUSE_GD_FT) from system libs.
> checking whether we should include PDF support...
> checking for PDF_setlinewidth in -lpdf... yes
> checking for PDF_setrgbcolor in -lpdf... yes
> checking for PDF_moveto in -lpdf... yes
> checking for PDF_curveto in -lpdf... yes
> checking for PDF_show_xy in -lpdf... (cached) no
> using libpdf from system libs.
> checking whether we should include TIFF support...
> checking for TIFFOpen in -ltiff... yes
> using libtiff from system libs.
> checking whether we should include EPPL7 support...
> including EPPL7 support.
> checking whether we should include PROJ.4 support...
> PROJ.4 support not requested.
> checking whether we should include thread safe support...
> thread safe support disabled.
> checking whether we should include ESRI SDE support...
> ESRI SDE support not requested.
> checking whether we should compile in MPATROL support...
> MPATROL support not requested.
> checking whether we should include OGR support...
> OGR support not requested.
> checking if GDAL support requested... yes
> checking for gdal-config... (cached) /usr/local/bin/gdal-config
> checking if PostGIS support requested... yes, user supplied pg_config
> checking if OracleSpatial support requested... no
> checking whether we should include WMS support...
> OGC WMS Compatibility not enabled (PROJ.4 is required for WMS).
> checking whether we should include WMS Client Connections support...
> OGC WMS Client Connections not enabled (PROJ.4 and libwww
> required).
> Compiling with -DIGNORE_MISSING_DATA.
> checking whether we should enable debug features...
> checking for PHP/MapScript module options...
> checking whether 'perl -V' works... yes
> checking for location of config.h or php_config.h...
> /usr/local/MapserverLinux/php-4.3.2/main/php_config.h
> checking whether we have PHP3 or PHP4... -DPHP4
> checking whether we should use PHP's regex... no
> PHP/MapScript module configured.
> creating ./config.status
> creating Makefile
> creating mapscript/php3/Makefile
> > I assume you compiled mapserver etc. yourself. It might help if we knew
> > the configure options you used for compiling mapserver AND for gdal also.
> > There might be a clue in that... Otherwise, I really don't know.
> Ok, now it works with the inexed tiff version of raster data, but it is
> quite dissatisfying if you have an unresolved error at your system....
> Carsten
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
