[Mapserver-users] Legend templates, classes and lines...
Daniel Morissette
morissette at dmsolutions.ca
Thu Jun 26 10:26:54 EDT 2003
Steve,
Something that changed between 3.6 and 4.0 is color handling. Could it
be that we need a call to msClearPenValues() in msCreateLegendIcon()?
Daniel
Steve Lime wrote:
> It's looking like a memory issue. The same legend works perfectly in
> 3.6. *argh*
> Steve
> >>> <Jean-Francois.Doyon at CCRS.NRCan.gc.ca> 06/24/03 03:43PM >>>
> Steve,
> Hmmm, well the loop counter is definitely a possibility, though you
> will
> notice that there is a class index value used in the generation of the
> filename for the class symbol, and it DOES increase ... (Just look at
> the
> filenames, you'll see a _0_ , _1_ , _2_ and so on for symbols of
> different
> classes within one layer).
> You know what I think I just noticed? All of our maps that use lines
> use
> different line styles and color for each class (At least so far as I
> can
> tell) ... this would explain why we never notied this.
> A couple of things to look at: Does it happen with the GIF legend? If
> not, I
> would suggest you try different line styles within that same layer for
> each
> class, see if suddenly the colors come out right ... That'll at least
> give
> you a good indication of where to look for the problem (which will be
> in the
> code!).
> I suppose that could yet be with some other counter ... I would be
> more
> inclined to suspect a pointer problem in this case.
> J.F.
> -----Original Message-----
> From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
> Sent: Tuesday, June 24, 2003 4:15 PM
> To: Jean-Francois.Doyon at ccrs.nrcan.gc.ca;
> mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] Legend templates, classes and lines...
> J.F. - I verified that the 3 files are indeed the same. I'll paste the
> layer definition below but it's pretty straight forward. Only thing I
> can think of is a stuck loop counter someplace. I'll try using a STYLE
> instead of just a COLOR and see if that helps.
> Steve
> # Railroad Rights-of-Way Prairies
> LAYER
> NAME mnrrpln3
> METADATA
> "TITLE" "Railroad Rights-of-Way Prairies"
> END
> MAXSCALE 500000
> SYMBOLSCALE 200000
> STATUS OFF
> DATA shapefiles/heritage/mnrrpln3
> TYPE line
> CLASSITEM 'quality'
> CLASS
> NAME 'Very Good'
> EXPRESSION 'Very Good'
> SYMBOL 'circle'
> COLOR 255 0 0
> SIZE 2
> MAXSIZE 3
> MINSIZE 1
> END
> CLASS
> NAME 'Good'
> EXPRESSION 'Good'
> SYMBOL 'circle'
> COLOR 255 125 33
> SIZE 2
> MAXSIZE 3
> MINSIZE 1
> END
> CLASS
> NAME 'Fair'
> EXPRESSION 'Fair'
> SYMBOL 'circle'
> COLOR 255 211 23
> SIZE 2
> MAXSIZE 3
> MINSIZE 1
> END
> END # mnrrpln3
> >>> <Jean-Francois.Doyon at CCRS.NRCan.gc.ca> 06/24/03 01:02PM >>>
> Steve,
> Hmmm, as you know we use HTML legends extensively, and as of yet I've
> never
> heard of anybody running into this kind of problem in our shop.
> It's a pretty simple legend template too, not much room for error.
> Also the page output suggests MapServer DID indeed render 3 different
> icons
> for each of the classes.
> I would try looking at the caching features of MapServer ... Maybe
> it's
> not
> overwriting previous icons? Clear the temp directory or something like
> that?
> Maybe you could send the mapfile along to see if there's anything
> weird
> in
> there? Otherwise, I'm afraid you'll have to look in the code!
> Good luck!
> J.F.
> Sent: Tuesday, June 24, 2003 1:48 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Legend templates, classes and lines...
> Hi Folks: I'm using 4.0 and wondered if anyone else has run into
> problems with legend templates with LINE layers and multiple classes.
> Check out the following URL:
> http://maps.dnr.state.mn.us/cgi-bin/mapserv40?mapserv=http%3A//maps.dnr.stat
> e.mn.us/cgi-bin/mapserv40&map_status=on&mapsize=800+750&map=LANDVIEW_HERITAG
> E_MAPFILE&template=/usr/local/www/docs/landview/heritage/templates/print.htm
> l&mapext=316287.17433148284+4891207.862044461+342298.221100423+4910705.97065
> 5294&layers=mnrrpln3+mnnpcpy3+mnsbspy3+lakes+ctybdln2+doq03im4
> It's a "print" layout and uses the legend template functionality. The
> problem is that the line legend for the "Railroad Rights-of-Way
> Praries"
> ain't right. The 3 classes should be red, yellow and orange (as in the
> map) and not all red. The polygon layer below it ("Sites of
> Biodiversity
> Significance") works as expected. Before I run to the source code I
> want
> to make sure I'm not doing anything stupid. The legend template is
> included below.
> Steve
